Go to Post Band geek FIRST geeks = uberparty! - Nuttyman54 [more]
Unread 24-01-2007, 12:17
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
Re: pic: This is our robot as of last night. Alot more should get done this week now
Originally Posted by foundbobby View Post
Are those the banebot transmissions?
How efficient have you guys determined they are?
Yes these are banebot transmissions. I did not run the robot yet, but i am confident that they will run just well. I will let you know how well they work as soon as i get parts to finish the robot.
Unread 24-01-2007, 12:27
dfukuba's Avatar
Technical Advisor
AKA: Daniel Fukuba
Originally Posted by mike1062 View Post
kool about how much longer do u think it will be tell u get done
We had planned to get the entire drivetrain done after the second week of build, but because of a mix up when order parts from mcmaster, we much make another order and wait until they come in. I will post pics when we get this done.
Unread 24-01-2007, 12:30
dfukuba's Avatar
Technical Advisor
AKA: Daniel Fukuba
He said 6WD. I'm hoping there's another border piece on the exposed side to support the other side of the tranny shaft. Otherwise.... ick. Seeing a shaft loaded like that seriously distresses me.
I plan to have a plate on the end, but did not plan to support the ends of the shafts. This was something that had also been bugging me for a while. I am thinking about making some kind of pillow block which will mount on to the side plate.
My original idea was to put the wheels as close to the gearboxes as i could so that most of the load would be on the bearings and not the shaft. Because i had never tried this before i was unsure how it would turn out.
--Daniel
Unread 24-01-2007, 13:11
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
I'm not sure I understand how that will fit in the 72" limit. If your arm is 50" long and the bot is 38" then you will be 88" in total (of course I'm just guessing).
That would only be if the arm were sticking straight up in the air. Most likely, the arm will be at an angle when deployed, reducing its height off the ground.
For example, at a 30 degree angle, the arm would only add 25" to the 38" height you mentioned. This team is probably within the rules.
Florida Institute of Technology
Ocean Engineering, '12
Unread 24-01-2007, 17:04
dancingfool's Avatar
dancingfool dancingfool is offline
Student Mentor
AKA: Chelsea
FRC #1718 (The Fighting Pi)
dancingfool is an unknown quantity at this point
Red face Re: pic: This is our robot as of last night. Alot more should get done this week now
Wow! That looks really good!
Good luck
Unread 24-01-2007, 17:30
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
Remember, the 72" limit is within the plane parallel to the floor, not the height. In any case, you're right that it's only a problem if your arm is straight out. I did some trig here that indicates that a widthless arm would be allowed to protrude up to 49.8 inches, minus rear bumpers, from the front of your robot. (Though that thread was speculative, my interpretation was upheld by the Q&A.) So, as long as they don't have their arm straight out while fully extended, they should be perfect.
2007 Pittsburgh Website Award
Team 1388 - Eagle Robotics
_
Unread 25-01-2007, 01:11
run the trap!!!
Team Role: Human Player
It seems like if there was more, the window motor probably can't handle the load very quickly.
We did some tests with our 5lb. grabber on the end of an arm aprox. the same length as this.
One keyang motor was not able to lift it. After adding a spring, which took virtually all the load off the motor, the keyang could lift it with ease.
However, even without a load on the motor, a light tap on the end of the arm was capable of stripping the gear inside the keyang. Further investigation found that the plastic gears inside these motors have very small teeth and are easily damaged.
Just a warning...
-Philip J. Fry
Unread 25-01-2007, 01:33
Just a warning...
The keyang motors aren't that powerful when compared to the others in the kit.
A FP motor (or the BB RS540, which has less power) into the 256:1 42mm gearboxes from Banebots make an easy to integrate motor with lots of torque.
Or take a hint from 968/254 (60 too maybe?) and swap you FPs into the drive to free up two small CIMs to use on the arm.
Unread 25-01-2007, 01:42
run the trap!!!
Yeah I forgot to metion that we had a reduction off the keyang...
Unless you can make a worm gearbox FPs and CIMs are backdrivable.
-Philip J. Fry
Unread 25-01-2007, 01:47
I specifically remember 254's driver telling me after last year that they were NEVER going to use the FPs in the drive train again. The FPs caused them too much trouble.
Unread 25-01-2007, 02:05
You're completely right. I remember 968 telling me the same thing...
Too many hours of robotics and too little sleep causes me to forget things....
Unread 25-01-2007, 12:20
dfukuba's Avatar
Technical Advisor
AKA: Daniel Fukuba
Just a warning...
I did not know that the gears were plastic. We will be using two of these on each side, with about a 1.75:1 reduction. I am hoping that this will be enough, in initial testing it seemed like it would work. But if we run into any big problems i may try to figure out a way to use the big Cim motors. Or get a gearbox for the FP motors. because it seems like we are so far ahead then we have been before, we will see if we can rebuild the whole superstructure after some real life testing.
Thank you for the heads up
--Dan
Unread 25-01-2007, 12:45
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The 49.8 inches is assuming that your arm has no width to it. The wider your arm is, the shorter it can extend without breaking the 72" x 72" box.
Unread 25-01-2007, 13:14
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
Well, firstly' the 49" is NOT taking bumpers in to account, and as lil lavery said, you have to take the width of the end of the arm into account.
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
Are things quieter than usual this year? Madison General Forum 23 26-01-2005 13:59
Now THIS is a robot! Matt Adams Math and Science 10 25-03-2004 19:33
This is how you get through week six: generalbrando Chit-Chat 11 22-02-2004 23:04
So how are things looking this weekend? archiver 2001 1 24-06-2002 02:43
How much growth should this place have? Ken Leung CD Forum Support 2 11-10-2001 00:29
