Go to Post And then I learned how to use the lathe...long story short, I ditched my plans to become a music major and became an engineering student. - Karibou [more]
Unread 26-01-2007, 01:00
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: pic: Servo Controlled Valve
Maybe I'm oversimplifying this but. Why not just run an additional variable regulator downstream between the solenoid valve and the vacuum generator?
This way you can operate the kit valves at an increased pressure (ie: 60psi) and then regulate the pressure down to your desired psi for the vacuum generator.
2016 Season; Game Announcer at
NYC Regional
SBPLI Long Island Regional
PC Controlled Robot EHaskins Programming 6 05-11-2006 06:45
pic: pneumatic actuation of ball valve Andrew Schuetze Extra Discussion 2 30-10-2006 08:40
Camera Controlled Robot douglass1371 Programming 1 19-02-2006 19:22
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servos controlled by RC? Obi Programming 5 01-02-2005 14:43
