Go to Post I actually see no issue about the sentence, but then im still in college and only half way edumacated, i am only eduma right now. - Alex Cormier [more]
Unread 26-01-2007, 15:49
ChrisSanborn's Avatar
ChrisSanborn ChrisSanborn is offline
FRC #2936 (The Robonauts)
ChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of lightChrisSanborn is a glorious beacon of light
Re: pic: 1584, lifter 6
Do you plan to pick up 2 robots with this design, or also have the option to pick up only 1?
Chris
edit: sorry, just found this same question asked elsewhere, (with another descussion of the same pic ) this thread can be killed.
Unread 26-01-2007, 15:55
pirates pirates is offline
FRC #1584
pirates will become famous soon enough
there will be one lift on each side, we can lift 2 or just 1.
Unread 26-01-2007, 19:22
How can you lift just one? It is purely a cantilever right? So, you've got ~120 pounds hanging out on one side of your robot. Your robot weighs ~120 lbs. What keeps it from falling over, if you don't have another ~120 lbs on the other side?
Unread 26-01-2007, 19:23
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
I have the same question about the cantilever... but some very nice machining!
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 26-01-2007, 19:25
Have you considered rotating the wheelbase 90 degrees so you can drive into alliance partners to pick them up?
Unread 26-01-2007, 19:28
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
That is really cool... but i still like our concept better.
note i said concept and not design... unfortunately.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 26-01-2007, 19:31
FRC #1584
there are outriggers in the works which will allow for lifting one at a time.
we thought about the best way to pick up robots and our wheel orientation, and we came up with just being able to park and have the others drive on us.
Unread 28-01-2007, 20:03
Jaime65's Avatar
Jaime65 Jaime65 is offline
AKA: Jaime
FRC #3398
Jaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud of
if this design is made to pick up other robots, are you sure you wont tip
2015 • Team #3398 Crushing Crusaders • Mentor
2008 – 2009 • Team #65 Huskie Brigade • Mentor
2003 – 2007 • Team #65 Huskie Brigade • Human Player
Most Of The Time You Will Fail, But You Will Also Occasionally Succeed.
Those Occasional Successes Make All The Hard Work And Sacrifice Worthwhile. - Dean Kamen
Unread 28-01-2007, 20:57
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
As stated in the post above yours, they are going to have outriggers to stabilize the robot.
Unread 28-01-2007, 21:28
Charger_07 Charger_07 is offline
AKA: Escue
FRC #0932 (Circuit Chargers)
Charger_07 has a spectacular aura aboutCharger_07 has a spectacular aura about
pretty cool design, you should try to get some video of that in action
Chuck Norris likes to knit sweaters in his free time. And by "knit", I mean "kick", and by "sweaters", I mean "babies."
Nick: "I'm not Nick"
Unread 28-01-2007, 21:38
FRC #1584
We tested it with about 120lbs, and it lifted marvelously. Judging by how it was able to lift that amount, we don't forsee any problems with robots that will approach 150lbs with the battery, bumpers etc...
ANOTHER VIDEO SOON TO COME
pic: 1584, lifter 4 pirates Extra Discussion 13 27-01-2007 20:54
pic: 1584, lifter 7 pirates Extra Discussion 4 26-01-2007 17:47
Team 1584, robot lifters pirates Robot Showcase 7 26-01-2007 15:39
Who's a Lifter? LordKronus Rules/Strategy 2 21-01-2007 00:00
Image Discuss: 401 Amazing lifter... CD47-Bot Robot Showcase 17 13-02-2003 16:15
