Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Unread 26-01-2007, 14:33
pirates pirates is offline
FRC #1584
pirates will become famous soon enough
pic: 1584, lifter 4
Unread 26-01-2007, 14:34
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
Re: pic: 1584, lifter 4
How is that being geared down (or is it)? It looks to me you are using the smaller CIM motors.
Unread 26-01-2007, 15:21
Engineering Mentor
FRC #0254
Looks like a banebots planetary is in there too? Either way, this whole forklift/lifting system looks gorgeous. I am interested in how exactly it works. Any help?
-Travis Covington
Unread 26-01-2007, 15:42
FRC #1584
They are indeed geared down with the banebots planetaries. in addition there is a sprocket and chain drive reduction and the diameter of the drum which houses the cable acts as another form of gearing it down.
I also started a thread in the robot showcase.
Unread 26-01-2007, 17:04
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
are you sure that the whole mechanism will be able to lift 120 pounds? just curious if you've tested it on a person or something yet...
Team #996 Programmer/President/Comedy Relief
"Why not stop by the robotics meeting after school today?" -Mr. Murray (enlisting me)
Unread 26-01-2007, 17:46
FRC #1584
not at all sure, but we sure hope!
Unread 26-01-2007, 22:19
FRC #1584
we tested it with a 120lb team member standing on the forks and it lifted him like it was its job! oh wait, it is it's job!!!!!!
Unread 26-01-2007, 22:59
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Keep in mind you really need to lift about 150 lbs+weight of your forklift.
120(robot)+13(battery)+15(bumpers)=148 lb.s
Unread 26-01-2007, 23:01
FRC #1584
actually when we designed it we were aiming for 150lbs, most of the parts where there is lots of stress are rated for about 300lbs, so we just had to make sure the lift was physically strong enough but after the tests we did i dont see any problems so far.
Unread 26-01-2007, 23:11
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Is there any sag towards the outer edge of the lift?
Unread 26-01-2007, 23:14
FRC #1584
nope, stiff as a board as far as I can tell, if so nothing major. It lifts 18in, we wanted to make sure to leave some room for wheels maybe hanging down depending on how we build the platform as well as if there were any sag.
Unread 27-01-2007, 13:13
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Is there any back drive when power is killed?
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 27-01-2007, 13:21
half geek's Avatar
half geek half geek is offline
For an extremely large value of 1/2
AKA: Greg R
None #0294 (Beach Cities Robotics)
Team Role: Student
half geek will become famous soon enough
Send a message via AIM to half geek
It looks like they have a ratchet attached to the drum.
73 de W6DXN k
Parse this:
g r e g a ``n o s p a m" r o b i ``a t" d e v ``d o t" j a v a ``d o t" n e t
Unread 27-01-2007, 20:54
FRC #5279
Yep, looks like your right
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
pic: 1584, lifter 7 pirates Extra Discussion 4 26-01-2007 17:47
Team 1584, robot lifters pirates Robot Showcase 7 26-01-2007 15:39
Who's a Lifter? LordKronus Rules/Strategy 2 21-01-2007 00:00
Image Discuss: 401 Amazing lifter... CD47-Bot Robot Showcase 17 13-02-2003 16:15
