Go to Post But he who has deeper insight realizes that concepts and ideas canot be contained in even the largest jar, bucket or box. You cannot touch or see these things, but you can be enhanced with knowledge and experience of them. - sanddrag [more]
Unread 28-01-2007, 00:49
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: pic: Team 1701 Electronics Board
Please, please replace that poor 12 gauge wire going from the 120A breaker to the power distribution block with a 6 gauge wire appropriate for the load. Otherwise its bound to go up in smoke once you get a few of those vics pulling amps - and that wouldn't be pretty!
And run a separate lead for the second maxi, as previously noted.
Other than that, it looks good - nice and compact and fairly tidy wire bundles
EDIT: Actually, I think based on <R57> you may need 6 gauge wire from the power distribution block to each of your breakers as well. I'm not an electronics guy though, so someone should check me on that. I couldn't find anything stating that you MUST have 6 AWG there, but the 7th bullet of that rule suggests such.
- Jeff
pic: Team 188 Electronics Board (Bottom) Mr. Lim Extra Discussion 7 02-02-2009 16:52
pic: Team 1712's 2007 Electronics Board Chuck Glick Extra Discussion 13 31-01-2008 07:07
pic: Team 1701 Electronics imax48236 Robot Showcase 5 20-02-2006 23:09
pic: TEAM 1636 Electronics Board LightWaves1636 Extra Discussion 1 14-02-2006 19:08
pic: 701 Electronics Board Doug G Robot Showcase 19 13-02-2006 19:40
