Go to Post Sometimes, it's all about the people. - nixiebunny [more]
Unread 28-01-2007, 13:21
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Re: pic: 240 lbs against wall!
Originally Posted by Goldeye View Post
Considering that you "have 40 lbs to play with." (http://www.chiefdelphi.com/media/photos/26448?), meaning you have no more than 80 pounds, 240lb pushing force implies a is simply not believable -- you'd need a coefficient of friction of 3! You better check your scale.
Who said they didn't put whatever extra weight they didn't have already on it on it (via gym weights or whatever)? That's what we did to our '05 chassis when we were testing a 6WD format with it. Just zip-tied two 45's to the top and bingo!
That pushing power is impressive, but I worry what might happen when the pushing (particularly in a head-on pushing match) is just a little bit off center with those omnis in the front...
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
pic: 1712 defends against 103 IraJason Extra Discussion 5 07-04-2006 07:34
pic: Chesapeake pit climbing wall RoboMom Extra Discussion 5 19-03-2006 23:32
pic: 862 on the Lexan Wall Joe J. Extra Discussion 3 12-03-2006 22:13
pic: 7 lbs overweight CD47-Bot Robot Showcase 9 23-04-2004 02:27
pic: TechnoKat High School Wall CD47-Bot Extra Discussion 22 22-05-2003 16:47
