Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Unread 29-01-2007, 10:39
Ray Jenkins Ray Jenkins is offline
FRC #0449
Ray Jenkins is an unknown quantity at this point
Post Re: pic: MiniMe
Originally Posted by dhoizner View Post
Did you find that the diamond plate provided an adequate grip for robots to climb up? For some reason, in my mind diamond plate equals slippery, and im not sure if all robots will be able to climb that (Please correct me if I'm wrong).
Other than that, it looks great!
Team 449 Found Fiberglass reinforced resin Grid. Used as grating in corrosive chemical conditions. Has embedded grit on side and smooth on the other. 1%deflection with 3 foot span and 260Ib load. 2.2 Ibs /Sqft. Is there any reason to have the middle? 1’ of a ramp? To save weight is there a wheel configuration that would have a problem with a ramp made of 2 tracks say 12” wide?
