Go to Post It does it automagically. - David Kelly [more]
Unread 29-01-2007, 15:54
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Re: pic: Team 1701 Electronics Board
Yes, as has been stated previously: #6 awg, please!
That 12 gauge will go up in smoke if you actually run all the victors in that configuration.
You may also want to plan on switching some of the leads to the Victors over to the other breaker panel. Many of the motors you may use only draw 20 or 30 amps, and those breakers won't fit in the 40 amp maxi blocks you have now.
pic: Team 188 Electronics Board (Bottom) Mr. Lim Extra Discussion 7 02-02-2009 16:52
pic: Team 1712's 2007 Electronics Board Chuck Glick Extra Discussion 13 31-01-2008 07:07
pic: Team 1701 Electronics imax48236 Robot Showcase 5 20-02-2006 23:09
pic: TEAM 1636 Electronics Board LightWaves1636 Extra Discussion 1 14-02-2006 19:08
pic: 701 Electronics Board Doug G Robot Showcase 19 13-02-2006 19:40
