Go to Post I am a firm believer that there is no model that can be transplanted/copied from one team to another and have the same level of success. There just isn't a formula for it. The mindset you should have is: "I know I have made a positive impact on my community". - tim-tim [more]
Unread 29-01-2007, 22:34
EnderWiggin's Avatar
EnderWiggin EnderWiggin is offline
07' Co-Team Leader
AKA: Carl Partington
None #0610 (The Coyotes)
EnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud ofEnderWiggin has much to be proud of
Re: pic: 1889's Electrical Module
One of the advantages of having such a compact electrical system is that it allows you to have short wires and hence less voltage drop from battery to motors.
If I were you I'd take advantage of this compact design and rewire everything and cut all the wires shorter.
pic: 1889's waterjet nest Tytus Gerrish Extra Discussion 7 17-01-2007 15:42
pic: Completed Mecanum Module Madison Technical Discussion 9 12-11-2006 19:39
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
pic: 494 Power Module KEY Extra Discussion 14 26-01-2005 17:50
