Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 29-01-2007, 22:44
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: 1889's Electrical Module
Originally Posted by EnderWiggin View Post
One of the advantages of having such a compact electrical system is that it allows you to have short wires and hence less voltage drop from battery to motors.
If I were you I'd take advantage of this compact design and rewire everything and cut all the wires shorter.
I thought short circuits were bad for robots??
Don
pic: 1889's waterjet nest Tytus Gerrish Extra Discussion 7 17-01-2007 15:42
pic: Completed Mecanum Module Madison Technical Discussion 9 12-11-2006 19:39
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
pic: 494 Power Module KEY Extra Discussion 14 26-01-2005 17:50
