Re: pic: 931 Preliminary Electrical Layout
I'm still not sure whether we can use the negative stud in power distribution. Can anyone give a definite answer?
That electrical layout looks very nice you guys. Great job!
Richard,
Looks really cool, nice job! I would eliminate the ground stud and return the negative leads directly to the distro block. You save some weight in #6 and crimp on connectors and lower the series resistance, not to mention a single point failure if the stud hardware loosens. How do you like the crimper and the Power Poles so far? We add a touch of solder to the connector just to be sure, before assembly. They crimp on the #12 Chalupa leads OK as well, but again a touch of solder just to be sure. |
Thanks, Al.
We will probably lose the stud when we compact the layout somewhat -- right now the footprint is still too large. I agree the stud takes up valuable space and is an extra failure point. Also, I am not sure that the stud is a COTS component. It was in an old (2003? '04?) KoP but I don't think it was custom made for FIRST. Anyway I would need to get a part number and price to show for material cost analysis if we want to use it on the robot. |
Richard,
It seems to me that they were available from Terminal Supply that year. |
But it does seem to be available at Hot Rod Wires. |
| IRI Schedule - PRELIMINARY | Chris Fultz | Off-Season Events | 4 | 05-07-2006 21:05 |
| pic: Team 931 Summation | RebelWithARobot | Extra Discussion | 8 | 10-05-2006 11:10 |
| Team 810: Electrical Layout, rev 1 | ForgottenSalad | Robot Showcase | 4 | 04-02-2006 00:03 |
| Team 931 Omniwheels | bheller | Robot Showcase | 7 | 19-02-2004 23:56 |
| Electrical wiring layout sheet | George T | Electrical | 1 | 11-02-2003 18:20 |
