Go to Post If you have the time to be caught up on Delphi and the Q&A forum, then you have time to go write a WFA entry. No more excuses. Go! Write! Now! :) - Jessica Boucher [more]
Unread 30-01-2007, 22:27
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Re: pic: XBot 2007 electronics panel
Originally Posted by fsayre View Post
It is ABS 1/4" plastic. We might still take some weight out of it, if we have time to take the electronics off and cut it before the panel is needed on the robot.
I like it... it is clean and looks nice!
Can we use any material for the electronics mounting board?
Also, is it necessary to add any dampers to limit any vibration or is this not an issue?
I am also considering using the 1/4" ABS plastic as well but wanted to make sure that there isn't any rules against using it.
thanks!
Unread 31-01-2007, 08:14
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Japper,
Nothing in the electronics is so fragile that it can't take a hit from another robot. There are things you do want to make sure are secure. The battery musst be mounted in such a way that it won't fly out in a crash with another robot. The PWM cables have a tendency to pull out if you don't tie them into position. We usually just loop the cable out of the device and tie wrap it to the mounting board next to the device. This goes for both ends, RC and Victor, Spike or servo. The power cables, if left to flop around, will loosen at the screw terminals of the Victors so tie those down as well. Time will tell if the terminal blocks will stand up to the vibration of matches. I am recommending that teams check the tightness of each one in the pit between matches.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-02-2007, 09:35
Japper's Avatar
Thanks Al-
Is there a rule of thumb regarding how much of the robot should be covered in Lexan to protect parts and besides the electronics panel, which areas should have this type of protection?
Unread 01-02-2007, 10:36
Rich Ross Rich Ross is offline
Let's get Desperate!!!
AKA: 830 Alumni
FRC #1504 (The Desperate Penguins)
Rich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond reputeRich Ross has a reputation beyond repute
Send a message via AIM to Rich Ross
Is there any chance at seeing an updated version of this panel? I know you said it was going off to be weighed, so im guessing it is completed by now. It appears very efficient and neat, and I hope that it meets your requirements well.
Unread 01-02-2007, 10:39
There is no robot rule for lexan coverings. It is up to the individual teams as to how much they want or can use with regards to weight since all nonfunctional decoration is included in the weight. We generally enclose most of the robot with either thin Lexan or punched aluminum. The Lexan is a good base for our stick on Wildstang decor and team numbers and is attached with Velcro to allow us access for repairs. The punched aluminum is riveted to the robot frame and is used to mount electronic and pnuematic parts. It is easy to mount these objects with ty wraps or hardware as needed.
Al
WB9UVJ
www.wildstang.org
Unread 01-02-2007, 10:41
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
What did you with the victor fan wires? do they go the speed controller power contact? we've always just sent them right to the circuit panel thing. is there an easier (shorter, really) way to do it?
if there is can you let us know?
"There is only one solution to this problem- We need more engines."
The good thing about the YMCA is if you can spell, you can dance.
Proud Eagle Scout
Unread 01-02-2007, 10:46
Mike,
I recommend teams wire the fans in parallel with the power input to the Victors. this is allowed under the rules and it is an easy indication that the Victor is getting power. You can shorten the wires leading to the fan and this will neaten up the wiring.
Al
WB9UVJ
www.wildstang.org
Unread 01-02-2007, 11:15
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
yah, but fans have a tendency to die and short out... I wire all mine to a seperate 20amp circuit breaker... if only i could get like a 5 amp or something.
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 01-02-2007, 11:45
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
The board came out to be about 7lbs with everything except the four remaining victors. The kids were half way through finishing the wiring up for those on tuesday and should finish tonight. If they do, I will post another picture.
Originally Posted by Al Skierkiewicz View Post
Mike,
This is what we did. We shortened the fan wires, and rotated the fans so that the wires go directly down to the power inputs to the victors. It is way easier and makes things much cleaner.
I have never had this happen to any fan on any machine I have ran in the past four years. Was there any specific circumstances that caused these failures?
Unread 01-02-2007, 12:20
There is no reason for the fans to die dependent on where they are wired. You do need to watch polarity and you must not wire them to the Victor outputs, power input only please.
Al
WB9UVJ
www.wildstang.org
Unread 02-02-2007, 15:17
GMKlenklen's Avatar
The "Masonater"
well now I feel sorta cheesy...
but anyways, If these fans are anything like computer fans, they can randomly die.
Thank you,
-of the MASMabots-
Unread 03-02-2007, 11:19
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Thumbs up Re: pic: XBot 2007 electronics panel
I noticed you were not using any relays. You might want to consider this based on your overall design. The setup does look nice and organized.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 03-02-2007, 11:23
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
The layout of the components is really neat. But I would worry that the wires the the VIC motors would be too small and would melt if the current was too strong.
Unread 03-02-2007, 23:06
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
Believe me, we have considered at great length the use of relays. Mostly because that generally means for us that we would be using pneumatics. We might end up with a relay added for a motor if we can't utilize a servo for a mechanism to raise our lifts.
The wires on the victors are the standard gauge as prescribed by the first rules. We have used it every year without problem.
Also check the pictures section... I will be uploading some updated stuff shortly.
Unread 03-02-2007, 23:32
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
did u guys use 10 gauge wire for the vics?
pic: Tin Cans 2158 Electronics Box 2007 lynca Extra Discussion 15 20-01-2007 02:03
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 22-11-2006 09:21
pic: Xbot vs. Cheesy Poofs, Round 2. Madison Robot Showcase 16 27-10-2006 00:18
pic: FRC 488 - XBot - Hex Madison Robot Showcase 5 21-02-2006 19:30
pic: 461 Electronics Logan Byers Robot Showcase 9 13-02-2006 06:39
