Go to Post When you start new threads, keep in mind that ChiefDelphi has about 14.6 million subforums about nearly everything you can imagine in the world of FIRST. You have to be in the forum you'd like for your thread to appear in when you choose to start a new topic. - Madison [more]
Unread 04-02-2007, 00:50
Re: pic: 696 - Insane wheel
1. The wheels ride roughly centerline with the frame rail, which is 1x2 box tubing (sitting vertically). So, that would put our ground clearance under the frame rail at 1.5". But, we have some other stuff that is a little lower. Final ground clearance will be about 1".
2. We wanted a 5" wheel, for the optimal speed and torque for our robot and strategy. We wanted it lightweight. We wanted a 1/2" bore with a 1/8" keyway. We wanted to use incline conveyor belting tread. We didn't want it to be like every other wheel out there. Find me something that meets that criteria, and we'll buy it. We couldn't, so we made it. Wasn't too difficult for an experienced machinist. Wasn't at all costly either. ~<$15 per wheel in material. These are about 0.3 lb each, not including tread or hold down ring. Pretty light.
Team 696 Design, "Reinvent the Wheel" fabbuki Robot Showcase 13 26-01-2007 03:15
pic: 696 Unveiled! sanddrag Robot Showcase 13 10-03-2006 01:45
pic: 696 Numbers sanddrag Robot Showcase 4 20-02-2006 19:20
pic: 696 Teaser 3 sanddrag Robot Showcase 5 13-02-2006 04:35
