Go to Post In the end the important thing is that the rookie members who make up the majority of our team were inspired and will try much harder next year. :) - aeniug2 [more]
Unread 05-02-2007, 01:39
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
Re: pic: team 1029 idlers and tensioners oooo aaaaa
If I am looking at the picture correctly, and correct me if I am wrong. There are two chains, each coming off of the main drive shaft and going to two different wheels. Also if you look closely, the idler and tensioner are both on the same bracket. From this, I would assume that the bracket is either slightly adjustable or secured. I would assume that is slightly adjustable so that when the chains were cut for each wheel, that the idler on the left could be put into place so that is tensions the one chain run. Then the Spring Loaded tension could tension the other chain run, without having to be moved from its spot, it uses the spring forced to tension it. But that is just what I get out of the picture and the knowledge that I have gained from my engineering classes.
Needless to say, I love it, and have been trying to engineer/manufacture a design for the team that i was a part of to use in their drive systems. Really neat, and would love to see it in action.
Mike
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
pic: team 1029 end of week 4... bjimster1 Extra Discussion 7 04-02-2007 00:24
pic: team 1029 teaser bjimster1 Extra Discussion 6 25-01-2007 11:13
pic: team 1029 shifter bjimster1 Robot Showcase 4 21-02-2006 10:23
pic: team 1029 bjimster1 Robot Showcase 9 20-02-2006 19:07
pic: team 1029 bjimster1 Robot Showcase 4 18-02-2006 20:55
