Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 05-02-2007, 09:00
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Re: pic: 179 USS Swamp Lobsta
How much does it weigh?
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 05-02-2007, 13:47
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
- That paneling works good for something off the shelf thats strong and light
- It needs to be supported min every 8" from an edge and the supports are in the axial direction of the ramp, not so much the sides
- there are rounded nylon end caps on all the floor contacting points
- right now we're about 5lbs over weight. But we have 2 of the large cims with 2 small cims installed currently. If we do not find ample weight savings in some other places, we may go back to the 2 smaller cims in each AM shifter.
- I do not have video of our other bots driving on it, however we did do that, and it worked great with our crappy wooden programming bot (woody). Also we placed 2 bots on top of it. I will get video of the deployment and 2 bots riding up it this week though, and post that.
I have learned that building a ramp is much harder than it seems. I wanted to build an arm and then have a simple ramp off the end but I couldn't get around the structural requirements needed to have a ramp that could last the rigors of 20+ competition matches.
Thanks for the compliments!
www.179swampthing.org
Unread 05-02-2007, 15:13
[quote=Swampdude;572328]
/QUOTE]
Why not put two small cims each to begin with? The Big ones have less power and weigh a lot more. Are you using the small Cims somewhere else?
Unread 05-02-2007, 18:42
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Where did you get the lexan from, and how much did it cost you? Our team did some inquiries and didn't find anything below $190 each sheet. Also, how much does it weigh?
~Nick/1334
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 05-02-2007, 19:04
Swampdude's Avatar
AKA: Dan Quiggle
~Nick/1334
It's this stuff the 16mm thickness. They sell it at lowes here in Florida. Although we have hurricanes here and you probably don't so it may not be on the shelf. it was $98 for a 4x8 sheet
Unread 05-02-2007, 20:07
swamp_child's Avatar
swamp_child swamp_child is offline
AKA: Cody
FRC #0179 (Children Of The Swamp)
swamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to all
man, right after I leave you guys take all the pictures
2009 Florida Champions thanks to 233 and 1649!
2008 UCF finalists thanks to 69 and 342
2007 world Finalist, thanks to 233 and 71, we love you guys
2007 Archemedies undefeated champions, thanks to 233 and 71
2007 UCF finalists thanks to 1902 108 and 386
Unread 06-02-2007, 07:33
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Looks really great, I was just wondering, have you tested it when a robot hits it from a running start? Knowing you guys it doesn't matter, but hey, I'm curious..
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 06-02-2007, 08:17
Swampdude's Avatar
AKA: Dan Quiggle
Not yet, but tonight we'll run it through its ramp paces. However that lowest panel is well supported since its short and just from walking on it, I think its going to do fine. When alliances climb on you you're right in front of them so they can see what they're doing. We found its not hard to drive right up the center even from far away (where the best structural support is). So I think the skinny ramps will even work good. We added width for the climber under diress. We were thinking of forklifts but decided if we drop someone that would be bad. This way if they fall off its their fault and leaves the control/decision to the drivers team whether to risk the climb or not. A 12" drop can be devastating to a bot not built for that. Once you get somone in the air and they get powered off, if you don't have them balanced right, they can roll right off.
Unread 06-02-2007, 09:22
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
Hey Dan and the crew looks like a beast of a robot again this year. The ramp looks great. When you see our bot you will figure out why. The name is priceless and perfect for that robot. I am glad to see the 05 basic shape and framework back in action. Good luck to the Swampthing team this year and we will see you in a few weeks with t21 v4 .
-Drew
Team 1251 The TechTigers
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
Unread 06-02-2007, 21:53
Swampdude's Avatar
AKA: Dan Quiggle
Here's a link to the video of us driving last years bot up the ramp
Unread 06-02-2007, 22:15
Alex Cormier's Avatar
www.TwoPencilDesigns.com
FRC #1405
ugh, i just dl'd the newest quicktime and all. i still can't view this or the other video.
Unread 06-02-2007, 22:17
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Hey Alex, did you install DivX?
pic: Children Of the Swamp 179 Tytus Gerrish Extra Discussion 6 13-04-2005 16:29
pic: 179 Swampthing Swampdude Robot Showcase 14 24-02-2005 00:22
pic: Swamp HoverCart CD47-Bot Extra Discussion 24 28-06-2003 00:26
swamp thing team 179 Danielle 212 Chit-Chat 2 24-06-2003 22:06
Swamp thing a swamp ramp? :) GateRunner Chit-Chat 5 02-04-2003 16:25
