Go to Post It's our first time actually doing the math for all of our mechanisms and for some reason math actually works. - Ginger Power [more]
Unread 05-02-2007, 23:43
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: pic: team 1029 idlers and tensioners oooo aaaaa
First off, thanks for all of your input.
Originally Posted by Justin Stiltner View Post
By the looks of it you have an automatic spring tensioner on your chain, but you may want to check the effects of driving in reverse, to the right in the photo on the tensioner, as the slack will be placed in the other side of the chain/ wheel connection, I don't know if you have thought of this yet, but you may want to try it before competition. If that is a locking type tensioner that isn't solely spring tensioned your ok.
but looking good guys/gals
Justin, no problems here since the tensioner/idler takes out all the slack so there is no slack regardless the direction the wheels spin.
Originally Posted by worldbringer View Post
Looks pretty.
Why do you have an idler on one side and a tensioner on the other--do they have different purposes? Also, what plastic is the tensioner made of?
Originally Posted by Cody Carey View Post
I was wondering the same thing... It appears that both chains are going to wheels; so wouldn't it make it easier to manufacture spares if only one mechanism were used?
Originally Posted by Mike o. View Post
If I am looking at the picture correctly, and correct me if I am wrong. There are two chains, each coming off of the main drive shaft and going to two different wheels. Also if you look closely, the idler and tensioner are both on the same bracket. From this, I would assume that the bracket is either slightly adjustable or secured. I would assume that is slightly adjustable so that when the chains were cut for each wheel, that the idler on the left could be put into place so that is tensions the one chain run. Then the Spring Loaded tension could tension the other chain run, without having to be moved from its spot, it uses the spring forced to tension it. But that is just what I get out of the picture and the knowledge that I have gained from my engineering classes.
Needless to say, I love it, and have been trying to engineer/manufacture a design for the team that i was a part of to use in their drive systems. Really neat, and would love to see it in action.
Mike
worldbringer and Cody, Mike is right, the idler and the tensioner are both mounted on the same bracket, one is spring-loaded the other is not. Mike, you pretty much nailed it perfectly. Also to Cody, you don't need spares if the engineering is done right!
Originally Posted by squirrel View Post
The green tensioner looks suspiciously like a McMaster-Carr 7332K9 or 7332K11.
I guess I should get a paper version of their catalog....this online stuff is hard to find if you don't know what to look for!
Squirrel, thats because it is! Though I don't remember how much tension force they are, I think its the weaker one.
Originally Posted by Caleb A. View Post
It appears that you have 4 wheel drive with all 4 wheels being traction wheels, you may want to run that on carpet and try to turn around. In my experience we have always had problems with the robot "walking" since tank drive requires low traction to turn. Other than that your setup looks sweet! i like the color of the tread on your wheels i wish we could have found that before we put ours together.
wrong to some extent...
Originally Posted by Arefin Bari View Post
They have a 6wd...
wrong. Arefin spreading lies, tsk, tsk.
Anywho, Caleb, you got the first part, we are using a 4 wheel drive or 4 x 6 to be exact. This is a tried and true setup for us, we used it last year. It is true this can be problematic for the reasons you described unless you know what you are doing and can account for it accordingly.
You can ask anyone who saw us at the Florida Regional or anywhere else that our bot had absolutely no problems turning, we were able to spin with the point of rotation being nearly perfectly in the middle of the robot!
Thanks for your thoughts and concerns anyways.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
pic: team 1029 end of week 4... bjimster1 Extra Discussion 7 04-02-2007 00:24
pic: team 1029 teaser bjimster1 Extra Discussion 6 25-01-2007 11:13
pic: team 1029 shifter bjimster1 Robot Showcase 4 21-02-2006 10:23
pic: team 1029 bjimster1 Robot Showcase 9 20-02-2006 19:07
pic: team 1029 bjimster1 Robot Showcase 4 18-02-2006 20:55
