Re: pic: 662 drivetrain wiring almost done
wow that electronics board looks roomy. nicely done. whatre the dimensions on that?
The electronics board is the entire bottom of the robot or about 34x23 minus the room taken up by the gearboxes, CIMs, etc.
Its so clean!!! What method are you using for tensioning the drive chain? In those outer gearboxes, does the chain sprocket drive the axel or is there a gear stage from the sprocket to the axel?
Looks very simple and organized, I'm a bit jealous!! |
Very nicely done. Enough space to remedy any sort of wiring problem.
It reminds me of what our electrical team is mounting in the belly of our chassis. Groovy deal. |
The center gearbox drives the center wheel directly. Chains to the front and back drive the front and back wheels directly. There are adjustable idler sprockets in the front and back wheel mounting plates to tension the chains.
| pic: Team 56 Almost Done | jfischer | Robot Showcase | 12 | 18-02-2005 23:41 |
| Pic: Team 20 almost done | Ein | Robot Showcase | 2 | 16-02-2005 20:55 |
| pic: Phoenix 703 "almost done" | MattB703 | Robot Showcase | 13 | 16-02-2005 14:34 |
| pic: 233 Roccobot (almost done) | CD47-Bot | Robot Showcase | 1 | 26-03-2004 10:54 |
| pic: 1067's robot (almost done) | CD47-Bot | Robot Showcase | 8 | 17-02-2004 21:41 |
