Go to Post Isn't the professional level for us called a job? - CalTran [more]
Unread 07-02-2007, 00:06
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
pic: Team 319 - Big Bad Bob's Lift System
Unread 07-02-2007, 00:07
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: Team 319 - Big Bad Bob's Lift System
Do you expect any trouble with your center of gravity if only one "wing" is occupied by a robot when you raise up? Basically, if only one side is loaded, you might tip over.
Unread 07-02-2007, 00:12
Robotics Engineer
If you look on the left wing, almost hidden by the table, there's an outrigger piston that fire's with the other 4. We figured if there's only one robot, they'll get on that side, problem solved. Oh yeah, we cruched the numbers, and we theoretically have 700+ pounds of lifting force.
Unread 07-02-2007, 09:33
Brandon Holley's Avatar
thats a lot of pneumatics.......how long does it take you to fully complete a lift?
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 07-02-2007, 10:46
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
We are using two of the same 2" cylinders. However, due to the tank restrictions, we can only deploy one at a time. How are you planning on using as many as you have at the same time?
Unread 07-02-2007, 12:15
Robotics Engineer
We just lowered our working pressure. At 60 psi, the 2" pistons crank out almost 200 pounds of force. We don't need 800 pounds of force to lift two 120 pound robots, so we lowered our working pressure to 30 psi. Giving us about 80 pounds of force per piston. This gives us twice the amount of air to work with and we still have enough force to lift two robots.
P.S. We haven't done a complete two robot lift yet, but it shouldn't matter. The pneumatic solenoids require power to switch in and to swith out, thus if we push the "up" button even a millisecond before the end of the match, it will still go up.
P.P.S. Our lift platforms and the feet we put on our pneumatics are removable. So, if there is a robot in our alliance that can lift better than us, we just remove those parts and we have almost 2 inches of clearance.
Unread 07-02-2007, 12:51
Pjohn1959's Avatar
That's cool!!!!
Good idea to lower the pressure. We found that the 2" pistons only dropped the air pressure by 18 pounds when actuated. We are able to lift 200 pounds on each ramp using just one piston.
Unread 07-02-2007, 13:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Correct me if I am mistaken, but it looks like the pistons raise your robot as well as the other two? So, given the max weight of a robot being ≈148 lb. (120+13 battery+15 bumpers), wouldn't you need at least 444 pound of upward force? The 4 central pistons each producing 80 lb.s only gives about 320 lb. of force. Even if the outrigger piston is also 2 in. (which it doesn't appear to be) that's still only 400 lb. of force.
Is there something I'm missing?
Unread 07-02-2007, 17:08
Robotics Engineer
We just did a test, and at 60 psi, we lifted two 200 lb kids. Add in our robot, and you have almost 550 lbs to lift. Plus we have air left over. I don't know why the other person can't fire both at the same time.
Unread 07-02-2007, 19:05
hayakuneko's Avatar
hayakuneko hayakuneko is offline
AKA: Joshua
hayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of light
Send a message via AIM to hayakuneko
hey u guys i have a question about the arm. if the arm is stored just like in the picture and there is a pneumatics cylinder on the ends of the wings (also like in the picture)... when the wings are stored how does the arm get its full range of motion?
2007 San Diego Regional Winners (w/ 330 & 835/1216)
2007 Los Angeles Regional Finalists (w/ 980 & 580)
Unread 07-02-2007, 19:17
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
clever idea with the pneumatic distribution, hope it works well for you. Also great idea to make them detachable, we might have to adapt that to our robot
not trying to cause any fights, but lil lavery try and be more supportive of teams.. i read your posts all over the place and you are constantly trying to figure out why things arent going to work... this is FIRST, we are putting innovative thinking to the test, ive seen some strange ideas become some of the best robots. keep posting tho, just be aware of what your saying.
Cold Fusion's 10th Season
Unread 07-02-2007, 19:48
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
I'd rather be warned than have a system fail, but people generally tend to know what they are doing.
Great idea, I like the fact that it can be deployed 1 second before the match ends... could very well come in handy!!!
Team 701
Unread 07-02-2007, 19:51
in between teams
AKA: Luke Van Oort
I haven't really noticed Sean being any more critical than others, but if that was the case, I think you misinterpret his intent. In a lot of cases it is very easy to make a mistake in your design or overlook a simple problem, and it is usually a good idea to ask about things that seem sort of risky or such, in the case that there is a mistake, or if there isn't one, to satiate ones own curiosity about how the limitations of a design were solved. For example, in this case it is very easy that the weight of the battery and bumpers weren't included in calculations. However, it appears that there was a bit on miscommunication in posting this time.
Team 1219: 2009 - Mentor
Unread 07-02-2007, 20:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm sorry if my posts have come across as aggression or sarcasm, when my intent is often merely either confusion, curiosity, intrigue, or concern. In some cases I post that something may have an issue, because, well, it may. It's better to be warned early than too late. I also often post about how teams have solved particular issues elegantly, the advantages of certain designs, or how a design reminds me of successful deigns in the past.
In this case though, 30 psi wouldn't have had enough force (as it was stated they may be using), but the 60psi they later said they were using generated plenty of force. Luckily here, there was no issue.
Back on topic. What kind of material are you going to put on top of the "wings" and what method are you using to deploy them?
Unread 07-02-2007, 20:51
Robotics Engineer
We have expanded aluminum going on top of the wings. But it was too heavy so we cut a series of diamond patterns out of it, making it perforated expanded aluminium. The platforms fall on their own, so we just pull a pin with a servo.
pic: BOB's Drivetrain Hoshua2nd Robot Showcase 19 01-03-2006 10:29
pic: Team 1640 - Lift Teaser coastertux Robot Showcase 6 02-02-2006 16:11
pic: 1213 GROVES HS / TARDEC LIFT SYSTEM groves Robot Showcase 6 17-02-2005 06:24
Pic. Team 1511 Lift Teaser Mirza95vx Robot Showcase 14 15-02-2005 19:30
