Go to Post The robot is talking to you, you must listen to find out what might be wrong. - Al Skierkiewicz [more]
Unread 08-02-2007, 00:23
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: pic: 662 drivetrain wiring almost done
Originally Posted by sonofdad123 View Post
wow that electronics board looks roomy. nicely done. whatre the dimensions on that?
The electronics board is the entire bottom of the robot or about 34x23 minus the room taken up by the gearboxes, CIMs, etc.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 08-02-2007, 10:50
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Its so clean!!! What method are you using for tensioning the drive chain? In those outer gearboxes, does the chain sprocket drive the axel or is there a gear stage from the sprocket to the axel?
Looks very simple and organized, I'm a bit jealous!!
Work Hard, Have Fun, Make a Difference!
Unread 08-02-2007, 11:38
Uncrash's Avatar
Uncrash Uncrash is offline
The People's Hero
AKA: Jake Augunas
FRC #1276 (Kaizen Blitz)
Team Role: Communications
Uncrash is an unknown quantity at this point
Very nicely done. Enough space to remedy any sort of wiring problem.
It reminds me of what our electrical team is mounting in the belly of our chassis.
Groovy deal.
2006 - BAE Granite State Regional Champions
2006 - BAE Granite State Regional Team Spirit Award
Mathematics is the language of the universe.
The Written Word is the language of the people.
Learn both and you will be wise beyond compare.
Unread 09-02-2007, 00:13
The center gearbox drives the center wheel directly. Chains to the front and back drive the front and back wheels directly. There are adjustable idler sprockets in the front and back wheel mounting plates to tension the chains.
pic: Team 56 Almost Done jfischer Robot Showcase 12 18-02-2005 23:41
Pic: Team 20 almost done Ein Robot Showcase 2 16-02-2005 20:55
pic: Phoenix 703 "almost done" MattB703 Robot Showcase 13 16-02-2005 14:34
pic: 233 Roccobot (almost done) CD47-Bot Robot Showcase 1 26-03-2004 10:54
pic: 1067's robot (almost done) CD47-Bot Robot Showcase 8 17-02-2004 21:41
