Go to Post I was proud that there was no whining, no finger pointing and no complaining. - Vikesrock [more]
Unread 07-02-2007, 00:32
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
pic: Team 319 - Big Bad Bob's Arm
Unread 07-02-2007, 00:41
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: pic: Team 319 - Big Bad Bob's Arm
Looks great!
Full rack capabilities and being able to lift up two robots at once is always nice
One question/caution I have for you is (I am assuming that you plan on lowering all 4 pneumatics at once to lift both yourself and the two robots you are carrying off the ground) how are you going to make sure that all four pistons extend at the same rate and same time? In 2004 we had 3 pnuematics lift our robot about a foot off the ground, then we had a hook that latched onto the bar and we simply retracted our pneumatic feet to score. The problem was we could never quite get the robot to raise up evenly, even after endlessly fidling with the variable pressure valves on each pneumatic to try and balance them. I am worried that if you dont get it just right the robot will go up crooked and perhaps drop one of the robots over the side or even bend a pnuematic shaft.
I like the idea though and its great you got it finished so soon so you have plenty of time to test
Mike C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 07-02-2007, 00:46
Nate Laverdure's Avatar
FRC #2363
Looks like a solid design. You are going to need rubber or plastic or something at the end of those pistons to avoid breaking the "no metal on carpet" rule.
Unread 07-02-2007, 08:08
jfish456 jfish456 is offline
FRC #0456
jfish456 is an unknown quantity at this point
Thumbs down Re: pic: Team 319 - Big Bad Bob's Arm
How long is the actual arm, not the tower. And in what position will it start the game. Im just curious how you will be picking up ringers off the floor (or will you?) and still be able to stay within 72 x 72 during the game.
Unread 07-02-2007, 09:10
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
Thats one nice looking arm. How easy is it to pick up off the ground??? How easy is it to remove the spoiler??
Unread 07-02-2007, 17:13
Robotics Engineer
Both are easy. The arm is on a turret, so we can pick up a tube and score without moving the robot.
Unread 07-02-2007, 20:54
Robotics Engineer
Unless I am mistaken, (and if I am please inform me) The robot can be placed diagonally in the 72x72 box, giving us ample room.
Unread 07-02-2007, 23:46
Matt Gardner's Avatar
Matt Gardner Matt Gardner is offline
...shiny.
AKA: Basil Mook~Sang
FRC #2200 (MM Rambotics)
Matt Gardner is an unknown quantity at this point
That arm just looks plain sick, that's all there is to it. Actually, it's a bit intimidating...RUN!!!!
---------------------matthew gardner--------------------------------------------------------------------
| Catapultam habeo. Nisi pecuniam omnem mihi dabris, ad caput tuum saxum immane mittam |
FIRST, Breathe. FIRST, Breathe. FIRST, Breathe. FIRST, FIRST. Crap.
Unread 08-02-2007, 01:09
FRC #0456
yes but assuming that robot is approximately 38 X 28 the front (or back, which ever end is where the gripper is at the start of the game) of the robot would be about 10 inches from the corner of the 72 X 72 inch box. now add about 34 inches for the distance from the front to the arm. now your down to only about 57 inches for the actual arm. im sure you have done the math it just looks like it will be close and i wasnt sure if you had thought about that rule.
Unread 08-02-2007, 11:33
Uncrash's Avatar
Uncrash Uncrash is offline
The People's Hero
AKA: Jake Augunas
FRC #1276 (Kaizen Blitz)
Team Role: Communications
Uncrash is an unknown quantity at this point
Interesting use of pneumatic cylinders. Thats going to be around 350 lbs of lifting.
Have you guys tested the lift capacity yet?
2006 - BAE Granite State Regional Champions
2006 - BAE Granite State Regional Team Spirit Award
Mathematics is the language of the universe.
The Written Word is the language of the people.
Learn both and you will be wise beyond compare.
Unread 08-02-2007, 12:21
Robotics Engineer
We tested the lift capacity, and we have about 700+ pounds of force. Check out the other picture of our lift system.
Unread 08-02-2007, 12:36
Weepy's Avatar
Weepy Weepy is offline
Space Dog
AKA: Adrian Choy
FRC #2047 (Team Challenger)
Team Role: Marketing
Weepy is just really niceWeepy is just really niceWeepy is just really niceWeepy is just really nice
Send a message via AIM to Weepy
That, for lack of a better word, is a beast. I'd love to see that arm in action.
I thought that you couldn't 'lift' the other robots at all, be them allies or enemies. Is this rule exempt for the last phase?
Adrian
-Head of Marketing
-Electrical Team
-Robot Fabrication Team
Freelance artist, college bound engineer, loving father.
Do you fear my karate?
2007 Wisconsin Regional XEROX Creativity Award and
2007 Midwest Regional Rookie All-Star Award recipients!
Unread 08-02-2007, 12:37
waiakea11's Avatar
waiakea11 waiakea11 is offline
FRC #1056
waiakea11 is on a distinguished road
wow that is a cool bot....ours dosnt look as good as that one....Wow...it's cool..lol
Unread 08-02-2007, 12:46
waiakea2024's Avatar
waiakea2024 waiakea2024 is offline
ZOMGWTHKTHXBAIBBQ!!!!
FRC #1056 (Kekoa o Haaheo)
waiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the rough
very nice arm. its so....armish
Unread 08-02-2007, 15:16
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
All rules of that nature are exempt when in the home zone. I don't think it necessarily has to be the last phase.
pic: Team 319 - Big Bad Bob's Lift System Ty Tremblay Robot Showcase 20 08-02-2007 14:49
pic: team 668 arm teaser2 burkechrs1 Extra Discussion 1 29-01-2007 19:12
pic: BOB's Drivetrain Hoshua2nd Robot Showcase 19 01-03-2006 10:29
pic: Team 358 Arm Ken358 Robot Showcase 12 13-02-2005 18:49
