Go to Post it is easy. you will have to define "easy" in your own terms. - Mike Martus [more]
Unread 08-02-2007, 17:31
Nate Laverdure's Avatar
FRC #2363
Re: pic: 121 Manipulator Prototype
This appears to be an end effector that can grab the ringers. Can the top and bottom drive opposite one another so that the ringer can twist in place? How will you control this?
Unread 08-02-2007, 18:34
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
What are the tubes and "pully" things made out of? where can I order some!!!
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 08-02-2007, 20:40
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Yes, the top and bottom can move independently. We are using two windows motors: one driving the top and the other driving the bottom. The window motor that drives the bottom is hidden from view. Go here for the latest episode of American Robot to see it in action.
The tubes are just regular 'ol PVC you can buy at any hardware. They're great to prototype with. The pulleys I believe are from McMaster, but I don't know the part number (Rob could answer that).
FRC78: 2010-Present
FRC121: 2002-2009
Unread 08-02-2007, 20:56
Greg Perkins's Avatar
7 years, allready!!???!?!?!
AKA: Mongo
The belts are "polycord" material, they come in length, you cut them to the length you want and fuse the ends together to make an endless loop. You can order them from McMaster or from Smallparts Inc.
I'm actually going to use some 1/8" cord for the tracks for my 3lb combat robot.
Unread 08-02-2007, 21:59
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
The belting is called Polycord. I got the belts and the pulleys from McMaster. Search for "round belt" and for "round belt pulleys" .I hope your credit card has a high limit.
Good Luck,
RAZ
Unread 09-02-2007, 01:36
run the trap!!!
Team Role: Human Player
Have you thought about how you are going to confront the issue of side-load on the belts?
We have run extensive tests on this type of system, and have determined that side-loads generated from twisting the tubes can easily dislodge the belts.
As for belts, I highly recommend neoprene belts from mcmaster carr. They have incredible traction.
I machined our own pulleys out of nylon (18 hrs. of machining w00t w00t!)
-Philip J. Fry
Unread 09-02-2007, 01:49
Matt Gardner's Avatar
Matt Gardner Matt Gardner is offline
...shiny.
AKA: Basil Mook~Sang
FRC #2200 (MM Rambotics)
Matt Gardner is an unknown quantity at this point
I'm fairly sure I've seen a video of this manipulator in action somewhere, and all I can say is AWESOME. Killer design, it should work great. (And if this is just a prototype, I'd hate to see the real one)
---------------------matthew gardner--------------------------------------------------------------------
| Catapultam habeo. Nisi pecuniam omnem mihi dabris, ad caput tuum saxum immane mittam |
FIRST, Breathe. FIRST, Breathe. FIRST, Breathe. FIRST, FIRST. Crap.
Unread 09-02-2007, 06:13
AKA: Tom Dolan
We have run extensive tests on this type of system, and have determined that side-loads generated from twisting the tubes can easily dislodge the belts.[/size]
The latest episode of American Robot (see my post above) has the gripper in action. One polycord was a bit bigger than the others, so it rolled off once or twice. We always cut an extra inch off the polycord before bonding it together...generally give a tighter fit.
The next design iteration is going to have shorter jaws anyways, and might have double pulleys...so in the rare event one does fall off, there will be back-ups.
FRC78: 2010-Present
FRC121: 2002-2009
pic: 1270's Base W/Out Manipulator redbarron Extra Discussion 8 15-01-2007 22:38
pic: Team 121 Picture 1 Kyle Fenton Robot Showcase 16 21-02-2006 17:36
pic: 121 in a blur Joe Menassa Extra Discussion 7 31-01-2005 13:31
pic: 121 Teaser Joe Menassa Extra Discussion 18 30-01-2005 12:33
pic: 121 Joe Menassa Extra Discussion 18 29-01-2005 21:56
