Re: pic: 121 Manipulator Prototype
What are the tubes and "pully" things made out of? where can I order some!!!
Yes, the top and bottom can move independently. We are using two windows motors: one driving the top and the other driving the bottom. The window motor that drives the bottom is hidden from view. Go here for the latest episode of American Robot to see it in action.
The tubes are just regular 'ol PVC you can buy at any hardware. They're great to prototype with. The pulleys I believe are from McMaster, but I don't know the part number (Rob could answer that). |
The belts are "polycord" material, they come in length, you cut them to the length you want and fuse the ends together to make an endless loop. You can order them from McMaster or from Smallparts Inc.
I'm actually going to use some 1/8" cord for the tracks for my 3lb combat robot. |
Good Luck, RAZ |
Have you thought about how you are going to confront the issue of side-load on the belts?
We have run extensive tests on this type of system, and have determined that side-loads generated from twisting the tubes can easily dislodge the belts. As for belts, I highly recommend neoprene belts from mcmaster carr. They have incredible traction. I machined our own pulleys out of nylon (18 hrs. of machining w00t w00t!) |
I'm fairly sure I've seen a video of this manipulator in action somewhere, and all I can say is AWESOME. Killer design, it should work great. (And if this is just a prototype, I'd hate to see the real one)
The next design iteration is going to have shorter jaws anyways, and might have double pulleys...so in the rare event one does fall off, there will be back-ups. Last edited by TD78 : 09-02-2007 at 07:45. |
| pic: 1270's Base W/Out Manipulator | redbarron | Extra Discussion | 8 | 15-01-2007 22:38 |
| pic: Team 121 Picture 1 | Kyle Fenton | Robot Showcase | 16 | 21-02-2006 17:36 |
| pic: 121 in a blur | Joe Menassa | Extra Discussion | 7 | 31-01-2005 13:31 |
| pic: 121 Teaser | Joe Menassa | Extra Discussion | 18 | 30-01-2005 12:33 |
| pic: 121 | Joe Menassa | Extra Discussion | 18 | 29-01-2005 21:56 |
