Go to Post There is no offseason. - Jeff Rodriguez [more]
Unread 09-02-2007, 00:13
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: pic: 662 drivetrain wiring almost done
Originally Posted by Doug G View Post
Its so clean!!! What method are you using for tensioning the drive chain? In those outer gearboxes, does the chain sprocket drive the axel or is there a gear stage from the sprocket to the axel?
Looks very simple and organized, I'm a bit jealous!!
The center gearbox drives the center wheel directly. Chains to the front and back drive the front and back wheels directly. There are adjustable idler sprockets in the front and back wheel mounting plates to tension the chains.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
pic: Team 56 Almost Done jfischer Robot Showcase 12 18-02-2005 23:41
Pic: Team 20 almost done Ein Robot Showcase 2 16-02-2005 20:55
pic: Phoenix 703 "almost done" MattB703 Robot Showcase 13 16-02-2005 14:34
pic: 233 Roccobot (almost done) CD47-Bot Robot Showcase 1 26-03-2004 10:54
pic: 1067's robot (almost done) CD47-Bot Robot Showcase 8 17-02-2004 21:41
