Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
Unread 09-02-2007, 06:13
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Re: pic: 121 Manipulator Prototype
Have you thought about how you are going to confront the issue of side-load on the belts?
We have run extensive tests on this type of system, and have determined that side-loads generated from twisting the tubes can easily dislodge the belts.[/size]
The latest episode of American Robot (see my post above) has the gripper in action. One polycord was a bit bigger than the others, so it rolled off once or twice. We always cut an extra inch off the polycord before bonding it together...generally give a tighter fit.
The next design iteration is going to have shorter jaws anyways, and might have double pulleys...so in the rare event one does fall off, there will be back-ups.
FRC78: 2010-Present
FRC121: 2002-2009
pic: 1270's Base W/Out Manipulator redbarron Extra Discussion 8 15-01-2007 22:38
pic: Team 121 Picture 1 Kyle Fenton Robot Showcase 16 21-02-2006 17:36
pic: 121 in a blur Joe Menassa Extra Discussion 7 31-01-2005 13:31
pic: 121 Teaser Joe Menassa Extra Discussion 18 30-01-2005 12:33
pic: 121 Joe Menassa Extra Discussion 18 29-01-2005 21:56
