Re: pic: Team 836 2-speed transmission
The transmission looks great. KUDOS
And it works too. :Q
Looks nice. I like how you guys are putting the motor inside the plate. Few questions...
1) What are the gear ratios on there? 2) Are you guys using only one small CIM per side? 3) Is there a way to adapt another small CIM or a big CIM into that tranny? 4) How heavy is that? 5) I can't really see the dog gear... but can you shift on fly? Good luck at the competitions and if you guys are at any event that I am attending, I will make sure to stop by and check you guys out. =) |
1) High gear is 21.96 to 1 Low gear is 65.88 to 1 (both of these are to the wheel) 2) Yes, one 2.5 inch per side 3) Yes, but a small redesign would be required 4) A whole whooping 8.8 pounds per each side with motor and pneumatic shifter 5) Most definitely We will be competing at the Trenton and Anapolis Regionals |
| pic: Team 836 Teaser # 2 | Bcahn836 | Robot Showcase | 6 | 05-02-2006 21:11 |
| pic: Team 836 Teaser # 1 | Bcahn836 | Robot Showcase | 10 | 31-01-2006 16:45 |
| pic: Team 836 Teaser # 1 | Bcahn836 | Robot Showcase | 6 | 15-02-2005 15:13 |
| pic: Team 836 CMU Camera | Bcahn836 | Robot Showcase | 2 | 12-02-2005 22:02 |
| pic: Team 836 2005 Drive Plate | Bcahn836 | Robot Showcase | 11 | 09-02-2005 10:13 |
