Go to Post Why did they get rid of the headphone jack though? =p - sportzkrazzy [more]
Unread 12-02-2007, 06:44
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: pic: 612 Game Piece Manipulator
The T-handle was temporary, and has has been replaced by a bolt. We changed the design so it does not require delrin inserts between the 80/20 runners. We just slip one section into the next. It has very low friction if kept vertical.
When the suction cup reaches the top limit, the yellow tape keeps pulling it, and the spring-mounted horizontal arm rotates the pool tube upward, to just the right height for the top goal.
We are using the FP motor to drive a winch, which winds up the yellow polypropylene webbing strap. The elevator works like a fork lift, where all the vertical sections rise up at the same time. It seems very effective, and can move from the lowest position to the highest in ~ 3 seconds, which was our design goal.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 12-02-2007, 09:28
shakil07's Avatar
shakil07 shakil07 is offline
FRC #0123 (Team Cosmos)
shakil07 is an unknown quantity at this point
Send a message via AIM to shakil07 Send a message via MSN to shakil07
our robot is similar to this robot
we are using pulley too
Received 2007 Game Piece yet? yodameister General Forum 10 24-01-2007 23:23
Game Piece Position almsfan21 General Forum 3 24-01-2007 20:11
pic: 2007 Game Piece Hint Wetzel Extra Discussion 39 07-01-2007 00:24
2006 game piece? Mike Schroeder Rumor Mill 55 08-01-2006 02:10
