Go to Post I tried to convince my team to use the force but no one would listen. - ngreen [more]
Unread 02-12-2007, 01:40 AM
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
pic: 701's 10 Victors
Unread 02-12-2007, 01:43 AM
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: pic: 701's 10 Victors
Would I be correct in assuming that there will be no pneumatics on this robot?
Look's like its gonna be a beast. Can't wait to see it at Davis.
Mike C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 02-12-2007, 02:43 AM
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
wrong, two I believe. and it's currently running just over 100 pounds with a 4 foot hieght.
Unread 02-12-2007, 02:51 AM
I think your victors are powering the air, or your scale is broken. That's insane! give us a pic of all the thin-ness!
Unread 02-12-2007, 03:02 AM
Alekat's Avatar
AKA: Alex
I agree a full-sized pic would be nice to look at, I'm just an alum so I can't do it.
The bot is coming along great though, from what I saw this last weekend. Maybe if Green (mentor) remembers to take more pics he can find the time to post one for you guys
Unread 02-12-2007, 03:39 AM
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
I saw it two weeks ago and I must say this thing was very well done when I saw it (I'm also an alumnus).
They are using some composites this year which helps contribute to the lightness. I'm not sure if they are using a compressor or not, but the two pneumatics are fairly small and light weight (used for opening the manipulator) so pneumatics shouldn't contribute to weight too much.
Team 701
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
FRC #2090 (P.E.T.T.)
nsr is on a distinguished road
Send a message via AIM to nsr Send a message via MSN to nsr
wow you guys must now be using a ramp or anything else?
this robot must be really heavy using 10 victors with 6 of them being used constantly during a match...what kind of a transmission are you guys going with?
Unread 02-12-2007, 03:50 AM
I believe they are using the banebots (?) transmission with 2 CIMs.
We are using a ramp type thing for the end of a match.
btw
I hope those aren't metal shavings at the bottom of the electronics plate (!?!)
Team 701
Unread 02-12-2007, 03:52 AM
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
haha they kind of do look like metal shavings >.<
hmm, wow your bot is really light then if you have all of that and a ramp
you guys should post a picture of what your bot actually looks like
Unread 02-12-2007, 07:10 AM
Doug G's Avatar
Coach / Teacher
Suspense is fun!! But really I just haven't had the time and no one else on the team is into posting pics. I place a couple more pics in CD-Media that will show up some time on Monday. But to answer some questions already...
1) Those are not metal shavings, it is a reflection from the camera flash of the fiberglass mounting panel that runs the entire bottom of the robot - very light!!
2) We will have 2 Carbon Fiber ramps powered by FP's - pic will be in CD Media Monday. The ramps are removable if we feel someone else on our alliance has a better ramp system. Two bolts and two wires is all we do to remove them.
3) We are using the 2 CIM Banebot 12:1 Transmissions for each side.
4) Why 10 Vic's?? 4 of them power the 4 CIM's for driving. 2 power our dual Globe Motor telescoping device, 2 power our Window Motors for our arm, and 2 power the FP's which "kick up" our 2 ramps. The 6 that get the most use are the 4 CIM's for driving and the 2 window motors that control our arm. With our bot in a down telescoped position, we can pick up tubes off the floor or from a HP and score on the 1st and 2nd rows of the rack.
5) We have a pnuematics system which includes pump, 2 tanks, and 2 cylinders for our "grabber". A pic of this will also be in CD-Media Monday.
6) The rest of the robot? I'll put a pic in CD-Media for you. We're still doing a ton of software testing... PID on our telescoping section, Encoders on each drive transmission, smoothing algorithm to reduce stress on BaneBot Trans, and a Potentiometer on our arm. Last year was our first year using encoders and PID, and now we are running with it. This is our first year using feedback from a pot to give us better control of an arm. Luckily we finished the robot 10 days early to give us plenty of time to get it working right and to practice.
Work Hard, Have Fun, Make a Difference!
Unread 02-12-2007, 07:28 AM
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
WOW!!! I thought that having eight victors was a lot. I have been wiring like crazy the last few days on our comp bot and practice bot. I would like to congratulate you electrician for his wiring job, of this daunting task.
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 02-12-2007, 07:35 AM
Doug G's Avatar
Coach / Teacher
I never thought we'd get to the point of using 10 victors, and time will tell if we are foolish for doing so. We started wiring last Monday and finished Friday. We customized many "PWM/sensor" cable lengths for the first time, which is painfully long task.
Unread 02-12-2007, 02:00 PM
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
congrats ^^
you should've seen our electronics in a third of a tool box. it was insane and the wired were all organized and everything. unfortunately there were issues about the "space" because everything was supposedly "crammed". ahh whatever lol
i hope you guys have alot of lightweight material because that sounds like alot of hardware on your bot
Unread 02-12-2007, 03:12 PM
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
[quote] 2 power our Window Motors for our arm [quote]
correct me if I'm wrong, arn't the window motors not variable speed, so wouldn't a spike be used?
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 02-12-2007, 03:19 PM
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
[quote=Cowmankoza;576771][quote] 2 power our Window Motors for our arm
really? i thought they would be used with a victor because they are a motor anyways
Team 701's finished animation! Salik Syed 3D Animation and Competition 6 02-14-2006 10:09 PM
701's 4" pnuematic robotic canon Doug G Chit-Chat 2 10-04-2005 09:32 PM
pic: Team 701's Bot Stacking Tetras Doug G Robot Showcase 2 02-24-2005 08:43 PM
splicing victors h0x4r Electrical 6 02-19-2005 03:46 PM
victors great_one411 Electrical 4 02-06-2003 09:08 AM
