Re: pic: 1482 LIFTS TWO
how much weight is on each site
Very impressive.
![]() EDIT: Do you plan to protect the outer rams? They look like if a robot tried to get on and hit one it be broken fairly easily. Last edited by EHaskins : 12-02-2007 at 16:32. |
why not just lift the other two ramps instead of lifting your own robot too...that's going to requre alot of weight from the cylinders that you're going to need to lift the robots, and alot of pressure will be required too
lifting just the platforms presents some problems
It does, but we at 2228 think we have it down.
Now its just the whole, getting it to work part... |
Are you running your compressor during the lift? Or will it lift the two robots, and your own, on the air in four tanks alone?
we know that ours don't count but we did it to avoid strengthining our drive system to hold 280 pounds. yes we are running our compressor we are protecting the rams and therei 140lbs on each wing we work on the kiss method yes we can lift off the floor if we dont desroy the carpet and it dose use a lot of air but it works
| TEAM 1482 LIFTS TWO | Rinaldi 427 | General Forum | 13 | 13-02-2007 01:36 |
| pic: Team 488 XBot two lifts getting closer | Fred Sayre | Extra Discussion | 8 | 04-02-2007 16:58 |
| 1482 Help with Compressor | Rinaldi 427 | General Forum | 7 | 31-01-2007 07:46 |
| RINGERS 1482 | Rinaldi 427 | General Forum | 0 | 25-01-2007 02:27 |
| part shipment help 1482 ! | Rinaldi 427 | General Forum | 0 | 25-01-2007 02:22 |
