Go to Post No one ever said that this was easy. - Jaine Perotti [more]
Unread 12-02-2007, 17:01
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: paper: Victor Calibration code
Since this paper is getting referenced, I figured I should add this note:
The code should still work exactly as-is on the 2007 RC. (Besides firmware, is there any difference between the 2006 and 2007 RC?) The most one should need to do is add the 2007 library. Don't replace the header files or you will loose compatibility with older controllers.
Victor 884 calibration Torboticsmember Electrical 13 15-02-2007 09:33
Victor Calibration railerobotics Electrical 11 16-01-2006 18:24
Victor 884 Calibration Incorrect Just3D Electrical 4 15-02-2004 15:20
White Paper Discuss: CopyCat Code v1.1 CD47-Bot Extra Discussion 7 31-03-2003 12:37
[white paper] Auto-Balance Gyro Code Brandon Martus Technical Discussion 3 21-06-2001 10:36
