Go to Post To be blunt: how many motorized carts do you see parked on the side of Einstein? - Koko Ed [more]
Unread 12-02-2007, 17:06
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: pic: FRC488 - Lifts Raised 1
Originally Posted by Lil' Lavery View Post
They're using gas springs.
Those Laverys... ...you can't turn your back on them ;-)
I was just about to correct my analysis (after blowing up the photo to see it better) when I notices that Lil' L just called me out.
Ah well... ...it is hard to argue with the truth.
A typical gas strut about that size has a stroke of about .2m and has a force of about 1000N. That means each spring is packing 200Joules. They've got 4 of them so it should be able to provide 800 joules or so. Plenty.
Very good,
I have another question. How do you tie the front an the back together? If I am a very heavy robot in front and light in the back will you lift me still or will the platform $@#$@#$@#$@#?
Do Tell.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Team #88, TJ2
pic: 1482 LIFTS TWO Rinaldi 427 Robot Showcase 13 13-02-2007 16:22
pic: Team 488 XBot two lifts getting closer Fred Sayre Extra Discussion 8 04-02-2007 16:58
pic: FRC488 - Hopper Mechanism Madison Extra Discussion 16 01-02-2006 13:11
pic: FRC488 - Overview Madison Extra Discussion 12 31-01-2006 13:16
pic: side view of ROCCOBOT-partially raised CD47-Bot Robot Showcase 9 11-03-2003 15:34
