Go to Post And, by the way, we're all weird. It's just a matter of how well you hide or show it. :D - Billfred [more]
Unread 12-02-2007, 17:27
Re: pic: 1482 LIFTS TWO
lifting just the platforms presents some problems
Unread 12-02-2007, 17:35
triggerhappy336's Avatar
triggerhappy336 triggerhappy336 is offline
Driver
AKA: Craig Porter
FRC #2228 (CougarTech)
triggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of light
Send a message via AIM to triggerhappy336
It does, but we at 2228 think we have it down.
Now its just the whole, getting it to work part...
Unread 12-02-2007, 20:51
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Are you running your compressor during the lift? Or will it lift the two robots, and your own, on the air in four tanks alone?
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 13-02-2007, 16:22
Rinaldi 427's Avatar
Rinaldi 427 Rinaldi 427 is offline
any help but programming
AKA: Angelo Rinaldi
FRC #1482 (the ghosts)
Rinaldi 427 is an unknown quantity at this point
we know that ours don't count but we did it to avoid strengthining our drive system to hold 280 pounds. yes we are running our compressor we are protecting the rams and therei 140lbs on each wing we work on the kiss method yes we can lift off the floor if we dont desroy the carpet and it dose use a lot of air but it works
team 1482 proudly Canadian. proudly student built
TEAM 1482 LIFTS TWO Rinaldi 427 General Forum 13 13-02-2007 01:36
pic: Team 488 XBot two lifts getting closer Fred Sayre Extra Discussion 8 04-02-2007 16:58
1482 Help with Compressor Rinaldi 427 General Forum 7 31-01-2007 07:46
RINGERS 1482 Rinaldi 427 General Forum 0 25-01-2007 02:27
part shipment help 1482 ! Rinaldi 427 General Forum 0 25-01-2007 02:22
