Go to Post Next year they should make Roombas the game piece. They're not very effective at vacuuming the rug that's for sure. - Koko Ed [more]
Unread 13-02-2007, 05:18
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: pic: Team 61
the vertical bar on the end. im assuming it retracts and extends and squishes the tube?
We do pick up the tube but not the way you think we do. the arm does go in and out. if the tube is on the ground the lower part of the arm pushes the tub down and then we pull the arm back which brings up the tube onto the arm itself.
very easy way to pick up tubes on the ground
Building FIRST robots since 1995
BVT Robotics
pic: team #2247 come to visit team #383 mayah Extra Discussion 1 29-01-2007 12:30
pic: Team 188's 2005 Student Drive Team J Flex 188 Extra Discussion 6 10-04-2005 05:31
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 334 Team Members after the CeBit Convention CD47-Bot Extra Discussion 2 29-05-2004 14:14
