Re: pic: Team 1872's controller board
the dimensions for it are 12'' x 45'' so yeah it will fit in the shelf and its approx. 2'' high
-The red buttons will have big holes(not bigger than the actual red circle to fit the joysticks. -The "d-pad" will have another hole for the "arm" joystick -The space above the would be start/select buttons will have a square hole for the operator interface. EDIT: All the cables for switches and pushbuttons would be under the top sheet. |
you guys must be big nintendo fans lol, you should made a giant Wii-mote.
We have a custom made sheet metal box that folds up for easy carrying. |
| pic: Team 296 Control Board | Pat Fairbank | Robot Showcase | 27 | 11-02-2008 15:20 |
| pic: Team 668 Wiring Board | burkechrs1 | Extra Discussion | 4 | 06-02-2007 01:56 |
| pic: Team 1701 Electronics Board | imax48236 | Extra Discussion | 10 | 29-01-2007 20:18 |
| pic: TEAM 1636 Electronics Board | LightWaves1636 | Extra Discussion | 1 | 14-02-2006 19:08 |
| Using Custom Inputs on the Controller Board | schenkin | Programming | 10 | 27-01-2005 10:26 |
