Go to Post A quote from the Southern California Regional Visitors guide: "If you are having problems the FIRST thing to do is ask your neighbor for help" - ChrisH [more]
Unread 14-02-2007, 20:16
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
pic: 1429 Ramps deployed
Unread 14-02-2007, 20:17
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
Re: pic: 1429 Ramps deployed
wow that looks really heavy without anything on it
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 14-02-2007, 20:44
waiakea11's Avatar
waiakea11 waiakea11 is offline
FRC #1056
waiakea11 is on a distinguished road
yeah it does look heavy....how do people get on?
Unread 14-02-2007, 21:15
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
ummmmmmmmmmmmmmmmmmmmmmmm.....
What's your ground clearance???
just wondering, and good luck.
Best regards,
Karthik
"freedom is voluntary self control” Mahatma Gandhi
Unread 14-02-2007, 23:45
angela's Avatar
angela angela is offline
Amore!
FRC #1852 (Amore)
angela is an unknown quantity at this point
that looks super-heavy. are you making it lighter somehow, or does it just look heavier than it is?
how would robots get up onto your platforms?
Unread 14-02-2007, 23:59
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
You know I am hoping that the material isn't just plain aluminum. I am sure the team thought about the weight issue before starting to build it.
... the other day when I walked in Team 1251's home and picked up a 2x4 ACM (Aluminum Composite Material), I swear I thought it would be 15-20 pounds, when it was really just about 5-8 pounds.
Unread 15-02-2007, 13:39
Pjohn1959's Avatar
It looks heavier than it is. It is made of punched aluminum. Each ramp weighs about 6 pounds. The ends of the ramps are flush with the ground on deploy, then the pistons raise the ramps to a height of 13 inches. More pictures to follow.
Unread 15-02-2007, 13:46
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
Better make sure that you don't put the metal right on the ground-that would be against the rules. Metal or hard plastics cannot be placed directly on the ground.
Unread 15-02-2007, 13:54
MrForbes MrForbes is offline
Team Update #11 addresses this issue, metal or hard plastics can be placed on the playing field as part of a ramp or platform, if they are properly designed.
Unread 15-02-2007, 13:56
coolguybigt's Avatar
coolguybigt coolguybigt is offline
engineer rock (software is fun)
AKA: T
FRC #2043 (Robo Squad)
coolguybigt will become famous soon enoughcoolguybigt will become famous soon enough
Send a message via AIM to coolguybigt Send a message via MSN to coolguybigt
how si the robot going to get on the ramp
Unread 15-02-2007, 14:33
wild guess: ramps unfold, robots drive on, then cylinders actuate to lift them up.
Unread 15-02-2007, 15:09
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
from up above
pic: 1712 Robot w/ Ramps Up, February 13 Chuck Glick Robot Showcase 4 14-02-2007 13:34
pic: FRC488 Lift Mechanism Deployed Madison Extra Discussion 17 03-02-2007 23:17
pic: 498's Aircraft Carrier Deployed Donut Extra Discussion 18 19-01-2007 15:03
Gate Ramps KWB@FIRST General Forum 14 17-10-2006 23:38
pic: 476 - wings deployed CD47-Bot Robot Showcase 8 02-04-2003 23:37
