Go to Post As everyone knows, our students don't actually design or build the robot, so to make it look like they were working on it for the video, we hid cookies inside the unfinished frame and turned them loose. It looks believable. - Mike Soukup [more]
Unread 14-02-2007, 20:16
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
pic: 1429 Ramps deployed
Unread 14-02-2007, 20:17
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
Re: pic: 1429 Ramps deployed
wow that looks really heavy without anything on it
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 14-02-2007, 20:44
waiakea11's Avatar
waiakea11 waiakea11 is offline
FRC #1056
waiakea11 is on a distinguished road
yeah it does look heavy....how do people get on?
Unread 14-02-2007, 21:15
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
ummmmmmmmmmmmmmmmmmmmmmmm.....
What's your ground clearance???
just wondering, and good luck.
Best regards,
Karthik
"freedom is voluntary self control” Mahatma Gandhi
Unread 14-02-2007, 23:45
angela's Avatar
angela angela is offline
Amore!
FRC #1852 (Amore)
angela is an unknown quantity at this point
that looks super-heavy. are you making it lighter somehow, or does it just look heavier than it is?
how would robots get up onto your platforms?
Unread 14-02-2007, 23:59
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
You know I am hoping that the material isn't just plain aluminum. I am sure the team thought about the weight issue before starting to build it.
... the other day when I walked in Team 1251's home and picked up a 2x4 ACM (Aluminum Composite Material), I swear I thought it would be 15-20 pounds, when it was really just about 5-8 pounds.
Unread 15-02-2007, 13:39
Pjohn1959's Avatar
It looks heavier than it is. It is made of punched aluminum. Each ramp weighs about 6 pounds. The ends of the ramps are flush with the ground on deploy, then the pistons raise the ramps to a height of 13 inches. More pictures to follow.
Unread 15-02-2007, 13:46
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
Better make sure that you don't put the metal right on the ground-that would be against the rules. Metal or hard plastics cannot be placed directly on the ground.
Unread 15-02-2007, 13:54
MrForbes MrForbes is offline
Team Update #11 addresses this issue, metal or hard plastics can be placed on the playing field as part of a ramp or platform, if they are properly designed.
Unread 15-02-2007, 13:56
coolguybigt's Avatar
coolguybigt coolguybigt is offline
engineer rock (software is fun)
AKA: T
FRC #2043 (Robo Squad)
coolguybigt will become famous soon enoughcoolguybigt will become famous soon enough
Send a message via AIM to coolguybigt Send a message via MSN to coolguybigt
how si the robot going to get on the ramp
Unread 15-02-2007, 14:33
wild guess: ramps unfold, robots drive on, then cylinders actuate to lift them up.
Unread 15-02-2007, 15:09
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
from up above
pic: 1712 Robot w/ Ramps Up, February 13 Chuck Glick Robot Showcase 4 14-02-2007 13:34
pic: FRC488 Lift Mechanism Deployed Madison Extra Discussion 17 03-02-2007 23:17
pic: 498's Aircraft Carrier Deployed Donut Extra Discussion 18 19-01-2007 15:03
Gate Ramps KWB@FIRST General Forum 14 17-10-2006 23:38
pic: 476 - wings deployed CD47-Bot Robot Showcase 8 02-04-2003 23:37
