Go to Post The best legacy of this little machine is the inspiration she provided to a whole generation of future explorers who witnessed the unveiling of a planet through the eyes of a robot. - dlavery [more]
Unread 14-02-2007, 23:20
Rabbit222's Avatar
Rabbit222 Rabbit222 is offline
reffed PARC for 3 yrs now
AKA: DA BUNNEY
FRC #0222 (Tigertrons)
Rabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really nice
Send a message via AIM to Rabbit222
Re: pic: Team 1510 robot in last week 1
Very unique design. Simple, clean and attention getting. I can see this machine going very far in the regionals. Best of luck and I'll be keeping tabs on your performance!
PARC 12 CHAMPIONS 222, 2753, 1640
2009 Archimedes Champions with 2753 & 1218 Einstein Semifinalists
2009 Philadelphia GM Industrial Design Award
2009 Pittsburgh Champions with 1218 & 1743
2009 Pittsburgh Judges Award
2009 Pittsburgh Autodesk Visualization Award
2008 Pittsburgh Motorola Quality award
2007 Pittsburgh Finalists with 48 & 1038
PARC 9 CHAMPIONS 25,222,423
Unread 14-02-2007, 23:22
silicon_ghoti's Avatar
silicon_ghoti silicon_ghoti is offline
AKA: I think I'm a freshman?
AKA: Luke
FRC #1425
silicon_ghoti will become famous soon enoughsilicon_ghoti will become famous soon enough
Very purtty. It's sleek and looks bound to work , can't wait to see it in action in Portland.
What? You guys still opperate in only 2 dimensions?
This is a BEAR, it saves you.
Ghoti is pronounced "fish," ain't that sumthin'?
Unread 14-02-2007, 23:50
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
probably one of the nicest looking bots I have seen this build season.
Few questions...
1) Are you guys using banebot or some other transmission (for drive)?
2) How low are the middle wheels? (unless you went team 25 style)
3) Are you worried about someone running into your camera and destroying it?
4) I may be very wrong, but it looks like you guys are using only one cylinder... in reality teams may score 8-10 tubes at most in one match, do you get enough throws out of one charge? If you do, you guys would be able to take the compressor off unless ofcourse you guys aren't stressing on weight.
Good luck at competitions.
Unread 15-02-2007, 14:59
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
I see four. Two vertical stacks of two. One is directly in front of the far rear wheel (from this angle), and the other is opposite it on the closer side (slightly hidden by the top frame bar
Unread 16-02-2007, 04:31
Caio's Avatar
Caio Caio is offline
Caio has a spectacular aura aboutCaio has a spectacular aura about
Few questions...
1) we are using the banebot transmission just as it came in the kit
2) The middle wheel is dropped 1/8th inch (thanks to 254's tip). Last year we dropped 1/4 in, that was a big mistake since you have a 1/2 rock when you change directions
3) We plan on elaborating a more protective case on the camera. There is a bumper (as shown) but we will do more to protect it (shield of some sort)
4)
I believe Arefin Bari means actuating cylinder. We only have one (on the claw). We do have 4 air tanks however. We were considering having no compressor but we chose to put the compressor on just to be safe. Our weight is currently ok (we measured at about 13 lbs below the limit last time i checked... need to do it again now since its closer to done) Since we don't use that much air, the compressor isn't running consistently, so we don't lose as much battery power as you would with a fully pneumatic powered robot.
Originally Posted by waiakea2024
nice bot you have a nice shade of red. well then, how does your arm work? good job!
How does it work? We have 3 sprockets at the bottom. The large one is driven from a fisher price mounted on the chassis behind it. The other two are welded onto a steel pipe which sits on a plastic "fitting" of sort that sits on the main shaft. the second fisher price drives the larger of the two, and the other has a 1 to 1 ratio to the top of the arm (second joint)... this allows us to move the lower arm with a "praying mantis" movement of the upper arm, but still have independent control of the upper arm. If you look at 254's robot from the large 2x balls, they had the same system but more spread out. We got the inspiration from the picture and created the design of our arm. Its nice since we have all our weight at the bottom, and only a shaft and sprocket at the top.
I'm on a different computer, but i'll post a closer picture of it later and put the link here for you to see. Keep your eyes open tomorrow for the pic.
Thanks for all the input everyone! I'm very excited for the competition and can't wait to see everyones bots! Gl!
Caio Tenca
Software Engineer
Founder of Washington SWAT Robotics
Ex-Team Manager, Mech. Leader of Westview Robotics Team 1510
Team 1510 co-founder
Former Team 955 member
Curie lives on in my heart <3
pic: 157 as of last week aztech75 Robot Showcase 4 15-02-2007 12:49
pic: Team 1893 Week 4 karpiron Extra Discussion 19 05-02-2007 23:36
pic: team 1029 end of week 4... bjimster1 Extra Discussion 7 04-02-2007 00:24
pic: This is our robot as of last night. Alot more should get done this week now that things are in place dfukuba Extra Discussion 28 25-01-2007 13:14
