Go to Post ...When you use ";"s instead of "."s; darn Java; - machman-2823 [more]
Unread 15-02-2007, 23:48
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
pic: 1288's Robot
Unread 15-02-2007, 23:52
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
Re: pic: 1288's Robot
looks really nice, good job
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 16-02-2007, 00:28
Aren_Hill's Avatar
Build Nifty Things
looks good Is that the final covering for the ramps? if so what is it? i think we should be able to get up it
see you in st louis
A guy who likes robots.
Unread 16-02-2007, 06:39
tbmantia's Avatar
see you in st louis
The covering is steel fencing material used for dog kennels. It has holes that are 2" x 4", the 4" sides go the width of the ramp so everyone will need to cross a 2" gaps. But most teams have 6" wheels, so it shouldn't be a problem.
Unread 16-02-2007, 09:15
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Did you consider omni wheels? Their rollers might have some trouble with the gaps.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 16-02-2007, 09:46
tbmantia's Avatar
I thought about that, I think it might be an issue but it might actually help because it would give a surface to grab a hold of. Of course it might also get stuck, we might have to add something if we get a omniwheeled bot in our alliance. Usually in St. Louis we have alot of teams with low budgets so Omni wheels are out of the question.
MasterZahn's Avatar
MasterZahn MasterZahn is offline
Master of all things electrical!
FRC #1652 (LakeView Legends)
MasterZahn will become famous soon enough
The only thing I would be conserned with, is if a 120lb robot would be supported by the steel fencing. Other than that I see nothing but success for this bot.
MasterZahn
Unread 16-02-2007, 10:15
tbmantia's Avatar
We drove our robot on it from last year and it work, it deflects a little bit, but it drove up just fine.
Unread 16-02-2007, 11:58
GaryVoshol's Avatar
Cogito ergo arbitro
You get to practice in the LIBRARY?
(since 2004)
Unread 16-02-2007, 12:04
tbmantia's Avatar
Unfortunately that is where we build our robot. We machine everything on rolling carts in the corridore and we pretty much fan out through out the library doing website stuff, assembling components, learning 3D Max, writing homework letters. It honestly isn't horrible, the worst part is that we must clean everything up every night spic and span. We used to be in the shop, but we had to move schools due to a lack of a teacher/sponsor.
pic: 233 robot teaser, yep, theres our robot ; ) ducttapedude Extra Discussion 20 15-02-2007 22:02
Team 1288's Website tbmantia Website Design/Showcase 5 12-02-2007 06:58
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
