Re: pic: 753 Arm with banebot motor
The forklift trolley is shown in the center, with a pinion gear driven by a 48:1 RS-540 tranny. It grips a rack milled into the surface of the rail the trolley slides on. The rail itself has another motor and a similar rack milled into the channel stock the rail slides in.
Both of them have quadrature encoders (Grayhill 63 series) tracking their movement, and limit switches at the bottom to set them up in the right spot. The righthand operator can press a button and the trolley moves to the proper level for low, middle, or high rungs, or the ground. Ari. |
| pic: Team 753 Arm | MIsanthropist | Extra Discussion | 6 | 17-02-2007 23:56 |
| Attaching Mini-Bike motor to stock banebot gearboxes! | brennerator | Technical Discussion | 2 | 29-01-2007 17:03 |
| small banebot motor with 64:1 gearbox | burkey_turkey | Motors | 16 | 29-01-2007 01:48 |
| Banebot 2 motor adapter | Ben Piecuch | Motors | 5 | 17-01-2007 16:06 |
| pic: Experimenting with a robotic arm | Guy_E | Extra Discussion | 4 | 14-01-2007 09:12 |
