Go to Post I wanted my team to be rewarded for something they do, not because they do it for the award. - MikePres [more]
Unread 18-02-2007, 01:38
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: pic: 1388 Presents: Lucky!
So yeah. Just got home from a little late night programming.
A sample can be found here:
http://www.eaglerobotics.com/videos/auton_demo.wmv
(6mb WMV9)
Because our "arena" is small, we can't run it as fast as we would like, and we can't simulate the starting position in relationship to the actual rack .. but you can get the idea.
That is done minor human control. If you look at the image here you can see the button box we're using. He's pressing the 3 buttons labeled "Align" "Approach" and "Score"
Align uses the camera to locate the rack and position itself, approach to come up to it .. and score to release the ring then back off.
Once those buttons are pressed, the controller takes over. We're still needing to do some tweaking, but it is looking quite promising.
And a small detail that Bryan neglected to mention, the drivetrain uses 2 AM Shifter 2's. Currently they're running single small CIMs, but once we get to competition we can install 2 FP motors with AM planetarys (some bad weather in Indiana has kept the pinions we needed from getting here on time). The robot seems to be rock solid this year. Feel free to ask any questions
*edit*
Forgot to mention a couple things.
Sensors - using a gyro, a pot on the arm, and a touch switch on the claw (to sense when the tube is ready to be locked in). And the camera.
Arm - Driven using the small CIM and the Banebots planetary, with the 16:1 conversion installed. That is one solid drive system for an arm.
Bumpers - Pool noodle bumpers (covered in Cordura) exist, but are not installed at the time of the photo.
Pneumatics - 2 air tanks and compressor, all cylinders are 3/4"
Controller - Equipped with an IFI backup charging circuit (which let us run the camera for about 6 hours straight before the backup battery finally died)
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
pic: Team 1388: Finished Mike Hendricks Robot Showcase 10 22-02-2006 22:52
pic: Team 1388: Done. Mike Hendricks Robot Showcase 12 23-02-2005 02:19
pic: Team 1388 Gearbox Mike Hendricks Robot Showcase 5 07-02-2005 17:26
pic: Team 1388 Teaser Mike Hendricks Extra Discussion 10 27-01-2005 10:28
pic: LUCKY RECEIPT!!! CD47-Bot Extra Discussion 18 24-04-2003 11:38
