Go to Post If that due diligence shows that a real need for action exists, *then* grab the pitchforks, and light the torches. - gblake [more]
Unread 19-02-2007, 10:30
LieAfterLie's Avatar
LieAfterLie LieAfterLie is offline
FRC #2028
LieAfterLie is an unknown quantity at this point
Re: paper: PID Control Theory for FRC Programming
Very helpful. You might want to move the P code example showing the #define KP 5 / 10 to between the P and I sections though, as it doesn't show I control.
I finally learned what this PID stuff is about, thanks.
You might want to also mention that since motor velocity control is a speed you're comparing encoder ticks per time rather than a target value that has a defined range, and therefore also give us a simple method for determining the range, such as maybe start at this many ticks per time period as the min/max, then scale it down when the motor is full and gives less than that number, then printf that max to initialize it to for future code so that it starts out at the right range. I know this really goes beyond the basic PID concept, but it is relevant to speed control.
SEMPER UBI SUB UBI
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
White Paper Discuss: An Introduction to C Programming for First Robotics Applications CD47-Bot Extra Discussion 10 26-11-2004 21:54
White Paper Discuss: Official 2004 Introduction to Programming Guide CD47-Bot Extra Discussion 4 26-01-2004 20:59
control system programming archiver 2000 17 23-06-2002 22:14
Where can i Find info on the control programming Matchew General Forum 1 14-01-2002 19:09
