Go to Post ...your education can be interesting and even fun. If you look a little farther down the path, you WILL "use this crap", and "this crap" can even be cool if you know how to use it. - Chris Hibner [more]
Unread 19-02-2007, 20:42
hiimcristhian's Avatar
hiimcristhian hiimcristhian is offline
Awesome uber super Rojas =]
AKA: Rojas
FRC #1228 (Robo-Tribe)
hiimcristhian is an unknown quantity at this point
Send a message via AIM to hiimcristhian Send a message via MSN to hiimcristhian
pic: Ramps in action 2.
Unread 19-02-2007, 20:44
AKA: Rojas
Re: pic: Ramps in action 2.
pretty cool isn't it?cool:
Unread 19-02-2007, 20:47
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I would like to know how it works.
1) What do you have on the tip of the cylinder that is sliding?
2) Even if there is something that is helping it slide, how is that piston not bending? In that angle, if you apply 150 pounds, I would think they would bend, but I may be wrong.
... some videos would be great.
Unread 20-02-2007, 13:04
Inverted Inverted is offline
AKA: Eric P.
FRC #1228 (Robo Tribe)
Inverted is an unknown quantity at this point
Send a message via AIM to Inverted
1) I'm not sure what you're asking. The piston is connected to a clevis, allowing it to swing. At the end of the piston is simply an aluminum disc that works better than a conventional nut for ground contact. This picture is at a bad angle, the piston pushes against the ground, not the robot.
2) The front wheels of the robot being lifted are on top of our robot's deck, not the ramp, so the pistons aren't supporting the full weight of the robot.
pic: 1429 Ramps deployed Pjohn1959 Robot Showcase 11 15-02-2007 15:09
pic: 1712 Robot w/ Ramps Up, February 13 Chuck Glick Robot Showcase 4 14-02-2007 13:34
pic: Wonderland Action 1 Jonathan Norris Extra Discussion 1 28-09-2006 10:05
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
pic: BattleCry Action KathieK Extra Discussion 1 19-06-2005 16:16
