Go to Post Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. Read the manual. - RoboChair [more]
Unread 20-02-2007, 02:00
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
pic: 1747 Turret Close up
Unread 20-02-2007, 02:02
monty1540's Avatar
monty1540 monty1540 is offline
College Student Mentor
AKA: Eric
FRC #1540 (The Flaming Chickens)
monty1540 is an unknown quantity at this point
Send a message via Yahoo to monty1540
Re: pic: 1747 Turret Close up
i like the use of ball casters for that big sprocket, it is hard to tell so i'll ask instead of guessing, is that also how you help withstand the forces generated at the rotation point?
-Eric
Current WPI Student and college mentor to 1540
1540:
2008 Portland Regional Winner
2008 Portland Regional Engineering Inspiration Award
2007 Pacific Northwest Regional Finalist
2007 Pacific Northwest Reigonal Chariman's Award
Unread 20-02-2007, 10:16
AKA: Allison Phelps
Yes the "ball transfers" help distribute the forces away from the rotation point. The "ball transfers" were chosen because they were a low friction method of supporting our arm uprights which are mounted to the sprocket. They also help reduce the amount the arm rocks back and forth when fully extended.
pic: 1559 Turret mounted bradleym1559 Robot Showcase 2 04-02-2006 09:14
pic: Tunring turret falconmaster Robot Showcase 7 26-01-2006 17:15
pic: Turret 2 CD47-Bot Robot Showcase 7 13-02-2004 19:20
pic: Turret 1 CD47-Bot Robot Showcase 1 13-02-2004 01:10
So close, but not close enough archiver 2001 1 23-06-2002 23:45
