Go to Post You can reduce the size of your wench. - ngreen [more]
Unread 20-02-2007, 19:31
Darkforces's Avatar
Darkforces Darkforces is offline
Froforces
AKA: Taylor Burch
FRC #1875 (Autonomato Atonamatons)
Darkforces will become famous soon enoughDarkforces will become famous soon enough
Send a message via AIM to Darkforces
Re: pic: Our spine
Nope its part of our actual robot.
Unread 20-02-2007, 19:44
Nate Laverdure's Avatar
FRC #2363
Re: pic: Our spine
I think he was talking about how to control the spine. You could control it with a model, if it was designed cleverly.
Unread 20-02-2007, 20:08
Darkforces's Avatar
Froforces
AKA: Taylor Burch
Re: pic: Our spine
Im sorry im not following could you please explain?
Unread 20-02-2007, 20:15
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
Re: pic: Our spine
What he is stating is that you could make a miniature version of your arm in order to control your robot, you have a feedback sensor on the model on the points of movement, and you have the same on the larger version and you just work it in the code to say when this is he (on the mini) this goes here (on the real one), im not sure of how its exactly done, but i have seen it done before
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 20-02-2007, 20:18
Darkforces's Avatar
Froforces
AKA: Taylor Burch
Re: pic: Our spine
Oh i get it know, crap now why didn't we think of that. Its a good idea unfortunately we didn't think of it and probably wouldn't of had time to do it.
Unread 20-02-2007, 20:52
silicon_ghoti's Avatar
silicon_ghoti silicon_ghoti is offline
AKA: I think I'm a freshman?
AKA: Luke
FRC #1425
silicon_ghoti will become famous soon enoughsilicon_ghoti will become famous soon enough
Re: pic: Our spine
Guess' for control:
1. A resisting flex seonsor allowing for the approximate bend of the antenna to be read.
2. A camera that looks for a "green blob" on the end.
and coolest (but least likely)...
3. Your using a fiber-optics cable and analyzing the light distortion to find how your bent!!!!
What? You guys still opperate in only 2 dimensions?
This is a BEAR, it saves you.
Ghoti is pronounced "fish," ain't that sumthin'?
Unread 20-02-2007, 21:23
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Re: pic: Our spine
The most direct (and probably easiest) method would just be to build a miniature version of the arm and put potentiometers where the motors would interface. Then you just read the pot values and map them.
If you design it, you can build it into a project box the size of a joystick base during your fix-it windows, and just plug it in at competition
Unread 04-03-2007, 16:41
goingdeafsoon5 goingdeafsoon5 is offline
FRC #1649
goingdeafsoon5 is an unknown quantity at this point
Re: pic: Our spine
that is crazy i cant wait to see it in action at the FL regional
I think we are using the same mecanum wheels as you guys
Unread 07-03-2007, 01:46
teenmisfit's Avatar
teenmisfit teenmisfit is offline
AKA: John Willis
FRC #0501 (PowerKnights)
teenmisfit has a spectacular aura aboutteenmisfit has a spectacular aura about
Re: pic: Our spine
This is def. gunna b the bot i want to go check out at atlanta! way cool and u need to release a video
Unread 07-03-2007, 02:29
viking1902's Avatar
viking1902 viking1902 is offline
Team Viking/Head Mechanical
AKA: chuckie
FRC #1902 (EXPLODING BACON!!!)
viking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of lightviking1902 is a glorious beacon of light
Send a message via AIM to viking1902
Re: pic: Our spine
I have been fortunate enough to see the prototype of this arm in action and I can vouch for its extreme awesomeness. Its probably one of the coolest arms that I have ever seen attached to a FIRST robot.
Too much bacon for the pan to handle.
Unread 07-03-2007, 09:23
Darkforces's Avatar
Froforces
AKA: Taylor Burch
Re: pic: Our spine
I know i promised video but there have been some technical problems but thursday i will post video from the florida regional for those who want to see it and wont be there.
Unread 07-03-2007, 13:17
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
Re: pic: Our spine
my mind, is blown
if that monster works, you guys deserve an award
please please please get a video up soon! i cant wait to see this!
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
Unread 23-08-2007, 21:15
Re: pic: Our spine
Did this ever end up working?
pic: Our crate LightWaves1636 Extra Discussion 13 08-04-2007 02:00
pic: Team 842 Tranmission Spine falconmaster Extra Discussion 16 12-01-2007 03:01
pic: Our robot ryan_f Robot Showcase 12 15-02-2005 02:00
pic: Our Animator CD47-Bot Extra Discussion 5 31-03-2004 19:09
pic: Our Bot CD47-Bot Robot Showcase 0 04-03-2003 19:21
