Go to Post My nephew...loves FIRST. He wants to be an X-Cat but since he lives in Atlanta and that's a heck of a long commute for meetings I told him he probably should strive to be the next best thing: a CircuitRunner. - Koko Ed [more]
Unread 21-02-2007, 12:19
WesleyC WesleyC is offline
FRC #1825
WesleyC is on a distinguished road
Re: pic: 1825
A few of Chuck's features:
Physical:
2 CIM motors powering high-traction wheels via chain/sprocket system
Shielded electronics case
Highly mobile and fast
3/4 of the robot's total weight centered over drive wheels, providing unparalleled traction for our weight
Incredibly light, coming in at 90 pounds including battery, 77 without!
I-frame arm construction prevents bending and twisting
Electrical/programmed:
Effective autonomous mode
Shielded wiring and programming redundancy protects against sensor damage
Programmed in such a way that it will refuse to break itself
Incredibly simple to drive
State programming enables robot's arm and wrist to return to a given position if bumped
Code has the ability to "learn" what the robot's current state is and some possible deficiencies, then work around them
Now for a few quick anecdotes...
Our arm, one might say, looks very heavy. Extremely heavy. Heavy enough that one wonders how that tiny fisher-price motor manages to lift it. However, it isn't so.
The arm is constructed out of a fiberglass/foamboard combination material that is extremely durable and strong, but very light. The whole arm weighs less than 5 pounds, and with the wrist and claw added it's still less than 7 pounds.
Some of our mentors were... shall we say, rather skeptical about a material this light. "How will it hold up under pressure?" they asked. "Won't it break off as soon as we try to use it?"
After an unfortunate incident involving a badly damaged ceiling fan (11-12 feet up, I might add--this robot will certainly be capable of scoring ringers on the high goal!) set to high speed, a completely undamaged arm and claw, and a team mentor spending several hours attempting to bend the brass fittings of his fan back into shape, the murmers stopped.
Our team members also were rather reassured after the robot slammed its arm into our rack at near full speed during the early stages of driving practice, shifting the full-size rack but not even putting a nick in the arm.
The robot is certainly back-heavy, however to date due to the control algorithms and other factors we have been pretty much unsuccessful tipping it unless we were absolutely trying to tip it. Also, all the major weight pieces (battery, drive motors, major structural elements) are fairly low, giving us a low COG. This also gives us enough traction to climb ramps easily.
