#16
Re: pic: Team 971's Robot
Does it bother you that this will be the first year (in quite some time) that 254/968 has decided NOT to use this design?
#17
Just out of curiousity... How did you come about this design? My team used it this year halfway based on drawings from when we did it in 2004. |
#18
I am not worried. This design may not be the best one out there, but it definately works well. They believe that they have a better design than the arm, and I want to see what they think is any better. If we get time, I want to write some code that changes the control from changing the angle of the joints to changing the position in the xy plane of the arm. I believe that they didn't like the way that the arm is not able to lift in a strait line without a very skilled driver.
#19
We started fully from scratch this year. It took me 2 days to draw the claw, and then another day to draw the entire arm. The arm gearboxes then took another ~2 days. I frequented team254.bcp.org often, but only used their design as inspiration, not something to dirrectly copy. We went over to 254's lab, and they reviewed our design themselves.
#20
Looks very good--I love how you kept the pneumatics nicely tied up and fairly protected. That's one thing I've seen missing a lot in the robots that use pneumatics; it looks scarily easy to get tangled up in a pneumatic hose when in close proximity with these robots.
Make sure those bumpers are extremely solidly mounted, though--you wouldn't want a robot hitting one of your bumpers and knocking it loose into a wheel! |
| pic: Team 469's Robot for 2006 pic 2 | Don Wright | Robot Showcase | 10 | 26-02-2006 21:03 |
| pic: Team 469's Robot for 2006 pic 1 | Don Wright | Robot Showcase | 11 | 24-02-2006 16:35 |
| pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! | sgsdragons | Robot Showcase | 4 | 01-03-2005 16:21 |
| pic: Team 237 Robot and Team | Scott Shaw 237 | Robot Showcase | 3 | 23-02-2005 19:54 |
| pic: Team 114 Real Robot Vs. Inventor Robot | James114 | Robot Showcase | 3 | 18-02-2005 13:02 |
