Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 23-02-2007, 00:38
razor95kds's Avatar
razor95kds razor95kds is offline
razor95kds has a spectacular aura aboutrazor95kds has a spectacular aura aboutrazor95kds has a spectacular aura about
Re: pic: 766's robot for 07
Originally Posted by Rex114 View Post
Does the wrist actuate independently? Or is it held parallel to the ground? Also, how many robots can you hold up?
Nice bot, I look forward to seeing it at SVR.
our wrist can actuate using a window motor, but was used for practice just as a 4-bar linkage. Right now we barely hold one robot and the ramp will most likely be removed.
You could always remove that pesky compressor (assuming your using it for shifting)
we use the compressor offboard and our programmer and another student built this wonderful box that plugs two cables into the side of the robot and starts charging the tanks.
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 469's Robot for 2006 pic 1 Don Wright Robot Showcase 11 24-02-2006 16:35
pic: 766's robot in repose razor95kds Robot Showcase 10 19-02-2005 11:58
pic: 766's mystery material MFS766 Robot Showcase 5 07-02-2005 08:09
pic: 766's drivetrain and frame Sillygates Robot Showcase 5 06-02-2005 01:21
