Go to Post Ok maybe you cant stop them, but you can utilize that pretty flashing LED pretty darn well! - Andy Grady [more]
Unread 02-23-2007, 05:44 PM
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Re: pic: 1276's 2007 3-Speed AM Gearboxes
ok, I'll be the first to say that is awesome!!!!!!!!!
What kinds of speeds do you get?
Have you discussed this design with AndyMark to see if maybe they'll market it for next year?
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 02-23-2007, 05:49 PM
Dan Petrovic's Avatar
FRC #0166 (Chop Shop)
Gah.
Here I was expecting to see what kind of beast 1276 will put out this year!
I guess I'm just going to have to wait another week...
Those are looking pretty sweet. We were the development of a 2-speed ball-lock shifting transmission before kickoff. This is kind of convincing me to try to work on a 3-speed.
Good luck at BAE, guys.
Unread 02-23-2007, 08:33 PM
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Around 4fps in low gear, 10fps in medium gear, and 15fps in high gear.
We haven't showed them to AM (but I expect they'll see it here). They aren't bullet proof like the 2 speed, without proper code and additional sensors it is possible to lock them up.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 02-23-2007, 08:56 PM
Billfred's Avatar
Billfred Billfred is offline
When they do get locked up, is it possible to unlock them? Then it quits being a bug and becomes a feature.
Like the mods--nice and clean!
Unread 02-23-2007, 09:02 PM
Yeah. If it is controllable then you have a 3 spreed transmission with brake....
so... is it?
Best Available Data
It is very possible to unlock, just shift the third gear dog back into neutral. The only real problem is if you were cooking across the field at full speed and then locked them up you might do some damage.
EDIT (In response to Sean): Yep, that's what I figured too. It's just that if you engaged it while you were driving, you could hurt something.
Unread 02-23-2007, 09:05 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I think he was referring to intentionally locking them up to create a mechanical braking feature.
The biggest issue about using the dogs to lock up the shifters is what happens when it does fail. If you accidentally lock up the gears (which may happen if you have a lock on command feature), or you recieve a significant force to the gearbox when locked up (not sure what force this could be, most external forces this large would probably just cause the wheels to skid well before a failure in the drive) the failure would almost certainly be losing gear teeth. And that spells disaster in a transmission.
Unread 02-23-2007, 09:08 PM
That is awesome then. Keep your code so you don't look them at high speed, but also put some code in that let's you lock it on command. It would be really useful for holding position on a ramp at the end of the match.
Unread 03-06-2007, 05:02 PM
Best Available Data
In case anyone is wondering, these gearboxes held up perfectly through our regional. There was never any "bad shifting" causing a lockup or teeth stripping or anything of that sort. We found the extra high gear most useful in this years game to race around the rack to play defense and then return.
If there is any interest, we plan on creating a white paper before next season. (There, a deadline, now I'll have to follow it. )
Unread 02-23-2007, 08:57 PM
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Aaaaah! I think my head just exploded from looking at this awesomeness. You guys are great. This is super cool.
I thought Kaizen Blitz was working on something interesting, as I noticed they were buying a few extra parts... but I would not have guessed this.
For all of the people who think that selling off-the-shelf gearboxes stifles the engineering and creativity of FIRST teams ... phooey on you... look at 1276 and what they have done. Excellent job!!!
Andy B.
pic: Outback system with modified Andy Mark gearboxes sam shawe Extra Discussion 5 02-21-2007 12:56 PM
pic: Team 948 2-Speed Gearboxes jfelser Technical Discussion 10 02-08-2007 11:26 PM
pic: 1276's Handouts Ian Curtis Extra Discussion 11 02-02-2007 05:03 PM
pic: 1276's 2006 Robot Ian Curtis Extra Discussion 8 04-17-2006 09:30 PM
pic: Team 1114 Gearboxes CD47-Bot Robot Showcase 16 02-19-2004 12:16 PM
