#16
Re: pic: Blizzard VIII
Looks like a solid bot guys. Hopefully we'll get to play with you at LA
#17
How do you deploy your ramps?
#18
Looks like another great robot from team 188, good luck at your regionals and see you at GTR
#19
Airline cable connected to two pins which hold the ramps upright. The cable is linked to a window motor in the centre of the robot. Soon as we need to deploy the ramps, we just run the motor. Originally we tried with a servo but it ended up not being entirely reliable. I'm sure someone else can provide more detail! There are also turnbuckles to adjust tension.
#20
You guys in Canada sure are coming out with some impressive bots. Is it possible that 296 will be removing the only from the title "First and only FIRST champions from Canada"?
#21
The ramps are deployed as J Flex stated. The leg supports have springs which help to push the ramp outward and then we let gravity do the rest. I believe I was told they deploy in about 2 seconds.
The robot in the picture is missing the cage over the center of the robot. We believe that if a narrow robot wants to drive over to the other side it will be able to. |
#22
nice robot
i wondering is that robot over weight and how high is it could ur arm put tube on all 3 spot |
#23
I'm very excited to see this robot (And team of course
) in Los Angeles in less than two weeks!Good Luck to you guys, ILL BE CHEERING FOR YOU! |
#24
Yes we can place on all three levels. Special thanks to team 25 for allowing us to modify their drive train design from last year. We believe that this has drastically improved our mobility system from last year. |
#25
Unless the folded up ramps prevents so, hope you don't get a tube stuck on the camera mount, otherwise you're not allowed to pick up any more to play with until you get rid of it
#26
shaun |
#27
Steve,
How much do the ramps wiegh? |
#28
I believe that they are about 40 lbs total. We want all teams to be assured that the ramps are solid, won't collapse, and wide enough to drive on. The widest ramp is 37 1/2 inches I believe so wide robots will have to be a bit careful. It shouldn't be to hard of a task as they are driving right in front of themselves.
Total ramp width, including robot, 12 ' 9". |
#29
| pic: 610 Coyobot VIII - Chassis View | Jonathan Norris | Robot Showcase | 1 | 10-02-2007 17:18 |
| pic: Blizzard | Steve W | Robot Showcase | 22 | 08-03-2006 08:32 |
| pic: Cyber Blue 234 - Falcon VIII | David Kelly | Robot Showcase | 11 | 24-02-2006 11:13 |
| pic: Cyber Blue 234 - Falcon VIII | David Kelly | Robot Showcase | 2 | 23-02-2006 23:37 |
| Blizzard Going Down? | Raven_Writer | Chit-Chat | 3 | 03-07-2003 15:54 |
