Re: pic: 1276's 2007 3-Speed AM Gearboxes
![]() Like the mods--nice and clean! |
so... is it? |
EDIT (In response to Sean): Yep, that's what I figured too. It's just that if you engaged it while you were driving, you could hurt something. Last edited by Ian Curtis : 02-23-2007 at 09:07 PM. |
The biggest issue about using the dogs to lock up the shifters is what happens when it does fail. If you accidentally lock up the gears (which may happen if you have a lock on command feature), or you recieve a significant force to the gearbox when locked up (not sure what force this could be, most external forces this large would probably just cause the wheels to skid well before a failure in the drive) the failure would almost certainly be losing gear teeth. And that spells disaster in a transmission. Last edited by Lil' Lavery : 02-23-2007 at 09:15 PM. |
That is awesome then. Keep your code so you don't look them at high speed, but also put some code in that let's you lock it on command. It would be really useful for holding position on a ramp at the end of the match.
In case anyone is wondering, these gearboxes held up perfectly through our regional. There was never any "bad shifting" causing a lockup or teeth stripping or anything of that sort. We found the extra high gear most useful in this years game to race around the rack to play defense and then return.
If there is any interest, we plan on creating a white paper before next season. (There, a deadline, now I'll have to follow it. ) |
| pic: Outback system with modified Andy Mark gearboxes | sam shawe | Extra Discussion | 5 | 02-21-2007 12:56 PM |
| pic: Team 948 2-Speed Gearboxes | jfelser | Technical Discussion | 10 | 02-08-2007 11:26 PM |
| pic: 1276's Handouts | Ian Curtis | Extra Discussion | 11 | 02-02-2007 05:03 PM |
| pic: 1276's 2006 Robot | Ian Curtis | Extra Discussion | 8 | 04-17-2006 09:30 PM |
| pic: Team 1114 Gearboxes | CD47-Bot | Robot Showcase | 16 | 02-19-2004 12:16 PM |
