Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 26-02-2007, 23:22
FRC #0234 (Cyber Blue)
Rookie Year: 1942
pic: 234 - Cyber Blue Robot at our Open House
Unread 26-02-2007, 23:25
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: pic: 234 - Cyber Blue Robot at our Open House
Does the grabber have a wrist of some sort to keep the tube at a certain angle relative to the ground or do you plan on scoring with whatever angle you happen to grab the ringer at? Looks solid, I'm assuming that with the two pneumatic extenders you can reach the top spider leg? And does the arm turret? I see a globe motor oriented vertically, and I assume its for a turret like system.
Great job guys!
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 26-02-2007, 23:35
run the trap!!!
Team Role: Human Player
Why did you decide you needed mechanical breaks? Can't the drive motors do that electrically?
-Philip J. Fry
Unread 26-02-2007, 23:44
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
So Chris, how about some videos? =)
Unread 26-02-2007, 23:49
Not near as well as mechanically.
The brake feature shorts the motor leads creating a braking force proportional to the shaft speed. So, it can't completely stop rotation.
My guess is that since they have a turreting arm, they plan to put the brake on to keep the base in place, then score with the turret.
Unread 26-02-2007, 23:50
Rookie Year: 1942
Grabber pulls the tube in at the right angle to score on any of the three levels - We only need to extend the arm to get to the top level.
Pneumatic brakes hold if we are pushed and will keep us on a ramp when power is cut.
Turret rotates about 30 degrees each way for placement.
No video - some more photos as soon as I figure out how to reduce the file size....
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
Unread 27-02-2007, 00:31
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Do I spy one of the tensioners from the large CIMs being used a chain tensioner? We used one of those two, and had issues with it being too weak to hold the chain taught properly under load, causing the chain to skip off the wheels. Have you had any similar issues?
Unread 27-02-2007, 06:20
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
Great looking robot guys, I can't wait to see it perform at BMR.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
Unread 27-02-2007, 07:50
Rookie Year: 1942
We are using four of them.
No problems so far with the driving and practice time we have had.
Chris Fultz
Unread 27-02-2007, 19:58
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Nice... Good Luck at regionals
Unread 28-02-2007, 21:05
chs1368 chs1368 is offline
FRC #1368
chs1368 will become famous soon enoughchs1368 will become famous soon enough
did you guys make weight?
Unread 28-02-2007, 23:25
Fireworks 234's Avatar
Fireworks 234 Fireworks 234 is offline
Purdue FIRST Programs Enthusiast
AKA: Joe Tonte
FRC #3180 (Blaise of Glory)
Fireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of lightFireworks 234 is a glorious beacon of light
Yes, our robot was shipped at 120 lbs, but we still need the flag holder.
Thanks for the good comments.
Blaise of Glory - 3180
Previous History:
Member - Cyber Blue (234) 2004-2007
Mentor - Harrison Boiler Robotics (1747) 2008-2010
Mentor - Blaise of Glory (3180) 2011-?
Eagle Scout as of 10/19/2006
Unread 08-03-2007, 08:34
Jimbo5051's Avatar
Jimbo5051 Jimbo5051 is offline
Rep' da Goat
AKA: Jimmie Nickerson
FRC #0829 (The Digital Goats)
Team Role: Electrical
Jimbo5051 is an unknown quantity at this point
Send a message via MSN to Jimbo5051
I love that bot!! Where did you get the blue metal?
2007 St. Louis Regional Winners
Unread 08-03-2007, 08:41
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Chances are that the metal has been annodized blue.
Purdue Alumni
Cummins, Inc.
Unread 08-03-2007, 10:06
Scott Ritchie's Avatar Unsung FIRST Hero
Scott Ritchie Scott Ritchie is offline
AKA: Fat Man in a Little Coat
FRC #3947
Team Role: Mascot
Rookie Year: 1997
Scott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond reputeScott Ritchie has a reputation beyond repute
Send a message via AIM to Scott Ritchie
Yes, it is annodized and you can see where we had late issues because there was supposed to be more blue than just that. O'well I guess some things feel the wrath of the six-week's monsters bite.
Scott Ritchie
"Before I'd get in the ring, I'd have already won or lost it on the road. The real part is won or lost somewhere far away from witnesses - behind the lines, in the gym and out there on the road, long before I dance under those lights." -- Muhammad Ali
pic: Cyber Blue 234 Transmission 1 David Hoff Robot Showcase 15 11-02-2005 16:09
pic: Cyber Blue 234 Teaser 2 David Hoff Robot Showcase 1 09-02-2005 15:59
Cyber Blue 234 robot movie Jon Anderson Robot Showcase 2 05-03-2004 08:17
Cyber Blue 234 robot weights calculator David Kelly General Forum 28 17-02-2004 19:30
Image Discuss: Cyber Blue 234 2003 Robot: Falcon V CD47-Bot Robot Showcase 26 03-03-2003 20:34
